C3 Tire/wheel question...
Old May 13, 2003 | 10:19 PM
tshort's Avatar
tshort
CI 7-8 Veteran
Default Re: C3 Tire/wheel question... (GrandSportC3)
sell them on Ebay... I actually have 6 rims.
4 rims are Centerline Auto Drags and 2 rims are TT2's.
The Centerline have 255/60R15 BFG's on them and the TT2's have 275/60R15 BFG Drag Radials on them...
Olivier,
When you do decide to sell the TT2's, give me a shout first. That's exactly the setup I need but I'm in no hurry.
:cheers:
[Modified by tshort, 9:19 PM 5/13/2003]
Old May 13, 2003 | 10:41 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: C3 Tire/wheel question... (tshort)
Olivier,
:cheers:
Do you also need the Drag Radials?? They have 5% thread left :lol: :lol: :lol:
Well - I make extended burnouts before my runs...
Old May 14, 2003 | 11:40 AM
tshort's Avatar
tshort
CI 7-8 Veteran
I should have known :banghead: Nah, in that case I'll probably find some less used ones with some cheap rims or something.
Still haven't joined the ellusive 11 second club?
Old May 14, 2003 | 12:27 PM
GrandSportC3
Haven't raced recently.. My differential mount was broken.. I only fixed it 2 days ago... Now - the temps are also too high for racing.. I will have to wait until Fall to go for 11's.. It doesn't make sense to race in 90 degree weather.. The higher temps alone cost me at least a tenth or 2...
Old May 14, 2003 | 11:02 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
I run 10" rallys with 5" backspace with the 295/50/15 radial T/A. There is less than 1/4 inch between the stock trailing arm and about the same clearance to the frame. I used a sledge to kiss the trailing arm to get some of the clearance and of course move the e-cable bracket to the top. You have to be careful that the rear spring doesn't get into the tire, drag racing shouldn't be a problem but roadracing i blew a tire because the back was too low and spring and bolt kissed the sidewall.
I have also tried circle track slicks (goodyear 27-10-15 they are about 12.5" wide not 10) with the 8" rally and they fit ok. I am going to try them on the 10" rally later.
The sig pict shows the 10 rally on course at Limerock. This is before the lowering. Right now there is only about 1/2 inch between top of tire and wheel well. It looks real good that low, but as i say i have to raise it a little to keep the spring away from the sidewall or maybe just take a grinder to the spring.
Old May 15, 2003 | 08:48 AM
GrandSportC3
Default Re: C3 Tire/wheel question... (turtlevette)
Thanks for the information and let me know as soon as you try the slicks on the 10" wheel.. :cheers: :cheers:
Old May 15, 2003 | 10:20 AM
Corey_68's Avatar
Corey_68
I know for sure 15X10's fit without rubbing, but I do not know the back spacing. My dad ran 15X 10's at the track, as you can see they do stick out.
Old May 15, 2003 | 11:00 AM
GrandSportC3
Default Re: C3 Tire/wheel question... (Corey 68)
If they stick out that far - he must have had around 4 inch of backspacing..
My flares are 1 inch wider than stock.. I know for a fact - that 15x10's with 5 inch backspacing are not going to stick out.. The only thing that I don't know is if they are going to rub on the frame...
Old May 18, 2003 | 05:12 PM
QuickVet's Avatar
QuickVet
Oliver, any luck on getting new wheels yet? decide what your going to do?
Old May 18, 2003 | 08:14 PM
GrandSportC3
Default Re: C3 Tire/wheel question... (QuickVet)
I have to know what backspacing I need first... It looks like I'll need 4.5 inches backspacing..
I also spoke with a guy on Friday at a local Cruise Night who runs 28 x 12.5 ET Streets on 15 x 8 Rally Wheels.. If those ET Streets fit on 15 x 8's... They will for sure fit my 15 x 8.5's Centerline Auto Drags... I still have to decide what I am going to do...
Old May 18, 2003 | 09:59 PM
QuickVet's Avatar
QuickVet
ya 4.5" BS seems to be the only way to go. Im going to order my rear wheels soon and i just hate knowing that im going to have to do more mods to the car to get them on. THis stinks. But that is my Vette for ya :rolleyes:
Old May 18, 2003 | 10:15 PM
GrandSportC3
My main problem is to find light rims that have 4.25 - 4.5 inch backspacing...
Centerline Auto Drag rims only come with 3.375 or 4.875 inch backspacing...
Old May 18, 2003 | 10:30 PM
  #33
QuickVet's Avatar
QuickVet
the real problem is that they all seem to measure it differently. THe draglites come with 4.5" BS but they are totally not like the original rims BS :crazy:
Old May 18, 2003 | 10:37 PM
  #34
JoeC427's Avatar
JoeC427
Are you trying to copy me or what? :p:
They should fit, and I guess I can handle another badazz C3 with Convo-Pros. I wonder if it will pick up any ET? Hmm I think I went a half a tenth faster, I can't remember, but good luck.
Joe
Old May 18, 2003 | 10:43 PM
  #35
GrandSportC3
I also don't think that they would work without spacers.. I wouldn't consider using spacers...
Old May 18, 2003 | 10:44 PM
  #36
GrandSportC3
Default Re: C3 Tire/wheel question... (striker427)
Joe
What backspacing do you use on your convo pros.. and what size tires?
Old May 18, 2003 | 10:58 PM
  #37
JoeC427's Avatar
JoeC427
Instant Message :thumbs:
Old May 18, 2003 | 10:59 PM
  #38
GrandSportC3
Thanks!! :thumbs: :thumbs:
