How much compression would I gain
Old May 10, 2003 | 03:25 PM
73 LS-4's Avatar
73 LS-4
Default How much compression would I gain
Next year I'll probably be swapping heads on my LS-4, the main goals being dropping weight and increasing compression from the dismall 8.25:1. Stock 049 heads have a 122cc chamber. I'm looking at the Performer RPM aluminum oval ports which have a 110cc chamber, how much would this raise the compression ratio :confused: Thanks for any help as always.
:cheers:
Pat Kunz
Old May 10, 2003 | 04:00 PM
WA 2 FST's Avatar
WA 2 FST
Default Re: How much compression would I gain (73 LS-4)
Hey Pat,
I've researched this a lot, too, since I have 8.75:1 CR with 118cc chambers.
From everything I've gathered, 14cc = 1 full point of compression. So, in your case 12cc = .857 gain in compression. Not bad! :)
Old May 11, 2003 | 10:24 AM
73 LS-4's Avatar
73 LS-4
Default Re: How much compression would I gain (WA 2 FST)
Thanks WA 2 FST, that would put me about where I want to be (at least 9:1) plus drop about 80lbs of weight and give me a better choice of cams to go with. Too bad my 049 heads have such large chambers becouse they flow really well. I believe i read in chevy high performance when they took a given engine and just changed the compression ratios on it, it was losing or gaining about 12-14% of its power per point of compression, of course there are a lot of factors here but even a 10% gain is quite a lot.
:cheers:
Pat Kunz
Old May 11, 2003 | 10:34 AM
Ganey's Avatar
Ganey
In general:
I suppose this chart needs some explanation. It shows the increase in power in % of a C/R increase. EXAMPLE: If the original CR is 9:1 on right of chart & it is increased (A line) to 12:1 (B line) on left of chart, then the increase in power is about 4.5%. If the power is increased from 9.5 to 10, the increase is about .08%.
Old May 11, 2003 | 11:11 AM
73 LS-4's Avatar
73 LS-4
Default Re: How much compression would I gain (Ganey)
Thanks Ganey,
According to the chart I'd be gaining less then 2% :cry , a far cry from the article I read. Thanks for the info.
:cheers:
Pat Kunz
Old May 11, 2003 | 11:59 AM
QuickVet's Avatar
QuickVet
great chart. thanks for the info.
Old May 11, 2003 | 01:53 PM
WA 2 FST's Avatar
WA 2 FST
Thanks Ganey,
:cheers:
Pat Kunz
The chart is great and Ganey sent it to me several months ago.
One thing to remember is that the gain in power is based solely on CR changes. Obviously, you'll be able to run a more aggresive cam with the higher CR and I bet those heads flow as well or better than your 049s at the lift you plan to run and in the rev-range your engine is designed for.
To How much compression would I gain
