Pulley misalignment
Old May 11, 2003 | 10:39 AM
Gordonm's Avatar
Gordonm
Default Pulley misalignment
Doing some work on the front end of the motor. I have all the belts off and noticed that the water pump pulley is off 1/8 of an inch from the balancer pulley. It has been running like this for about 4 years maybe more. I am running a Fluidamper on mine. This might be slightly different size from the original. I have had this past 7000 rpm and never had a belt come off. I am replacing the belts just because they are older. Should I shim out the water pump pulley or just leave it alone. What do you think?
Old May 11, 2003 | 12:16 PM
Steve Straus's Avatar
Steve Straus
Default Re: Pulley misalignment (Gordonm)
I think you should. Are these the original pulleys? If so, then the fluidampr is probably skinnier like you said. 1/8" isn't all that much, but if it can be shimmed, then I'd do it.
Old May 11, 2003 | 01:45 PM
bence13_33's Avatar
bence13_33
Gordon:
Personally I wouldn't. Why change something that works?
Old May 11, 2003 | 04:06 PM
Gordonm's Avatar
Gordonm
Default Re: Pulley misalignment (bence13_33)
I just put it back together and it runs fine. I'll keep an eye on it to see if there are signs of belt wear. Its only 1/8 of an inch, not much.
Old May 11, 2003 | 05:03 PM
Jack71's Avatar
Jack71
My last vette w/ the 400 had the same thing, but I never had a problem. Although I never had it up to 7000rpm!
I think that amount is trivial.
Old May 11, 2003 | 05:06 PM
Matt Gruber's Avatar
Matt Gruber
this is a good example of "blueprinting"
it is rarely done but it is desirable.
Old May 11, 2003 | 11:25 PM
no_radio's Avatar
no_radio
Default Re: Pulley misalignment (Matt Gruber)
Is it misaligned so that it's too far out (towards the radiator) or too far in (towards the block)? If too far out you may have a non-Corvette water pump, which I understand is about 1/8" shorter than a regular small block short water pump.
Jeff
Old May 13, 2003 | 11:43 AM
Steve Straus
Default Re: Pulley misalignment (no_radio)
Jeff
It's actually like 1/2" shorter. With a long water pump on the engine you can fit your hand behind the pump in front of the timing cover. With the short pump you can barely get a sheet of paper in there.
I'd still call fluidampr and ask if this is normal.
To Pulley misalignment
