Calling C3er's with TPI
Old May 12, 2003 | 10:56 AM
mean8t's Avatar
mean8t
Default Calling C3er's with TPI
What throttle cable are you guys using? ( I tired the corvette cable but it was too long)
What upper radiator hose are you guys running? Are you usin the TPI water neck?
TIA
Josh
Old May 12, 2003 | 11:16 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Re: Calling C3er's with TPI (mean8t)
I'm using a Lokar cable for the TPI. Works perfect, but pricey. As far as water neck, I'm using the 360 degree adjustable unit from Street and Performance. You can then use the stock hose.
Old May 12, 2003 | 11:22 AM
mean8t's Avatar
mean8t
Default Re: Calling C3er's with TPI (Budman78)
Badman-
Are you using the Lokar cables for both the gas pedal and TV cable? All I need is the gas pedal cable. thanks
Josh
Old May 12, 2003 | 11:26 AM
Budman68's Avatar
Budman68
St. Jude Donor '07
Yes, but I have a Lokar 350TH kickdown cable I will sell you cheap.
Old May 12, 2003 | 11:31 AM
mean8t's Avatar
mean8t
I bought the TV cable for an 85 Vette and it fit perfectly. But the gas pedal cable off the same car was about 10" too long. So I ordered the camaro cable and we'll see.
Josh
Old May 12, 2003 | 11:43 AM
Budman68's Avatar
Budman68
St. Jude Donor '07
Cool, if not try to modify the stock one.
Old May 12, 2003 | 11:50 AM
PatsLs1vette's Avatar
PatsLs1vette
upper radiator hose use a 96 caprice 5.7 fits great,thats what im using, im also using a 87 trans am throttle cable and that works fine also.all i had to do was bend the gas pedal under the dash out 3/4 of an inch and it works fine.
[Modified by patsnitrovette, 11:52 AM 5/12/2003]
To Calling C3er's with TPI
