I would like to see some dyno sheets to verify that motor is putting out 650+ horsepower. I'm not doubting it but I would like to see some proof.
The motor has aluminum rods, making it pretty much useless on the street. if you wanted to make that car a street/strip combo you would want a set of 4340 H-beams for that motor. Those aluminum rods on the street wouldn't last very long.
I notice he wasn't very specific with the motor combo (i.e. aluminum intake and R-Port heads...no cam specs at all). The heads must be cast iron if he didn't list them as aluminum.
I thought maybe since it was a drag car that there might have been a Ford 9" or a solid axle of some sort under it. You would have to be careful launching that car with 650hp, slicks and a independant rear suspension.
I thought the same thing about the rods. Not really needed unless you have 13:1 c/r+ & strict race car. I would also like to see more info on the motor.
You can see some more pictures of it here http://www.converter.cc/internet_specials.htm
Since the number on the car indicates that it runs as an A stock automatic I would guess that it CAN produce 10 second time slips.
The class should also explain why there is no information about aftermarket cylinder heads. This is a stock car, REALLY stock, extra special stock in fact.
Well - he also still has the independent rear suspension... I don't think that the rear end is going to be able to take that much power.. If the numbers are correct - the car needs a Ford 9 inch...
I hope to be running some 6.99 to 7.0s in the 1/8 mile soon which would be In the 10s. I still have a Independent rear. Now I have had alot of work done to It .
Heat treated gears,stronger clutch packs, the spindles trued. It's hard to tell with metal parts sometimes they can last sometimes not.
I wouldn't want to see my rear end falling apart in the middle of the track.. If I would go that radical... I would go with a solid axle...
GrandsportC3, Your running low 12,s almost In the 11s. Now If you get In the 11,s your going to want to go faster. Will you stop there.
I agree a soild axle is the best.
I know of a local 70 or 71 vette BB/Auto/nitrous, In my area that runs at the track I do and runs 6.50s @ 103/105mph In the 1/8. Man thats flying!! And he still has a Independent rear. So I know they can take some abuse If built right. I have an article from hotrod mag from late 80s on 66 l88 vette with a 250 shot of nitrous. That ran a 9.99 at 141mph with the stock rear end, only added track bars and has run the same rear for eight years with out breaking.
Now I have a friend that broke a halfshaft backing out of his driveway in his 66 vette.
I had to laugh at that.
Glenn:
I agree with everything you have said. The last time I was at the track there was a '74 Corvette down there. He was running a ZZ502 crate motor. He was running 12 flats at like 112MPH. He was running a TH400 w/ 3.90 gears and slicks. I watched him launch his car and hear a loud BANG. Then I heard the motor free rev. The driveshaft and one halfshaft were spinning but the car wouldn't move.
I'm keeping my fingers crossed. With my 117.72MPH trap speed, 4.11 gears, 4 speed tranny and slicks I haven't broke anything yet (knock on wood).
