Rear spring bolt removal
Old May 13, 2003 | 09:00 AM
Brettmc's Avatar
Brettmc
Default Rear spring bolt removal
Put the rear of the vette up on stands and removed the rear wheels. I jacked up the composite spring. While doing this I noticed the top of the bolts are rising out of the t-arm and the bottoms are hanging on the end of the spring. The top of the bolt is really leaning towards the differential. Do I need to raise the rear susp.? Remember, the rears wheels are off and the back of the vette is up on jackstands. The susp is fully extended. Should I be doing this with the wheels on and the car on the ground?
Brett :thumbs:
Old May 13, 2003 | 09:21 AM
Bobchad's Avatar
Bobchad
Default Re: Rear spring bolt removal (Brettmc)
You just want to get the tension of the bolts so you can remove them. Whether the slack is on the top or the bottom shouldn't matter. Mine were rusted and I just cut them and pulled them out from both ends.
[Modified by Bobchad, 9:22 AM 5/13/2003]
Old May 13, 2003 | 10:32 AM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
Take the car off the stands and let the wheels rest on the floor. Put a floor jack under the spring (you may want a C clamp on the spring so the it doesn't slip). Jack up hte spring until it lifts enougth to remove the bolt. I just replaced my bushings last winter. Surprisingly this was easy and fast. It helps if you have the tire bucket removed, as you have a lot more room to work with.
Old May 13, 2003 | 10:34 AM
gliot1's Avatar
gliot1
One correction..............I did have the car on jack stands when I jacked up the spring.....sorry.
Old May 13, 2003 | 02:22 PM
Brettmc's Avatar
Brettmc
Default Re: Rear spring bolt removal (gliot1)
Ok, thanks!
Brett :thumbs:
To Rear spring bolt removal
