Small Block Head Bolt Leaks
Old May 13, 2003 | 02:50 PM
SC71LT1's Avatar
SC71LT1
Default Small Block Head Bolt Leaks
Just replaced heads on my 71 LT-1. Both rear (lower) head bolts are leaking (through the threads). Any helpful hints or methods to ensure these bolts won't leak? I've been told that these bolts commonly leak on older chevy small blocks. I just pulled both bolts, coated thoroughly with Permatex and re-torqed.
Old May 13, 2003 | 03:49 PM
Pete79L82's Avatar
Pete79L82
Default Re: Small Block Head Bolt Leaks (SC71LT1)
All the head bolts on any stock block small block go into the water jackets and require sealer. Sometimes they will not leak with out sealer if you are lucky. Any good quality sealer will work (permatex, silicone, ect).
Drain the coolant out of the block, remove the bolt , apply sealer and retorque. Make sure that you look at all the bolts under the valve covers also because if they leak it will put coolant into your oil.
Old May 13, 2003 | 04:00 PM
SC71LT1's Avatar
SC71LT1
Is their a drain plug on the pass side of the block?
Old May 13, 2003 | 04:08 PM
MasterDave's Avatar
MasterDave
Moderator
Yes, but you will be better off just pulling the lower radiator hose off.
Old May 13, 2003 | 04:09 PM
ram82fire's Avatar
ram82fire
There is a block drain on both side 1/4 npt !
gman
Old May 13, 2003 | 06:08 PM
71coupe's Avatar
71coupe
I've found what works best on head bolt threads is Permatex Thread Sealant with Teflon, part no: 14A.
I had bad luck with Felpro Gray bolt prep p/n GRA2, & Felpro "tight", p/n 604. Both of the Felpro sealers were recomended to me, but they both leaked. They also harden up which makes a big mess with pieces of hardened sealant getting everywhere when you remove the bolts - the Permatex dosen't harden.
Old May 13, 2003 | 08:40 PM
vettfixr's Avatar
vettfixr
Default Re: Small Block Head Bolt Leaks (71coupe)
:iagree:
To Small Block Head Bolt Leaks
