Pushrod guideplates on an L82?
Old May 13, 2003 | 11:27 PM
page62's Avatar
page62
Default Re: Pushrod guideplates on an L82? (BSeery)
Okay, so why did they waste money on unneeded guideplates instead of giving us better heads? Inquiring minds want to know!
Old May 13, 2003 | 11:45 PM
Tom73's Avatar
Tom73
Default Re: Pushrod guideplates on an L82? (page62)
yes, they are the 76cc 1,94 x 1,5 thin casting open chamber design smog heads. Absolutely the worst head ever produced by GM. Restrictive, weak, poor chamber design,.. JUNK.
ALL L82s had the 2.02 valve heads. But the same casting number was used for the L48 heads but with small valves. Has been the same since the '70 LT1, same head casting but different valve sizes.
tom...
[Modified by Tom73, 8:49 AM 5/14/2003]
Old May 14, 2003 | 09:11 AM
Ganey's Avatar
Ganey
Default Re: Pushrod guideplates on an L82? (Tom73)
L-82 had guideplates though not needed. Different castings no. have been used, depends on yr.
Old May 14, 2003 | 12:13 PM
JJ Deuce's Avatar
JJ Deuce
Also, doesn't the presence of the guideplates mean you can't use the umbrella type valve seals?
Old May 14, 2003 | 12:21 PM
page62's Avatar
page62
Default Re: Pushrod guideplates on an L82? (Jeff 6T9)
It shouldn't be a problem because the seals are under the valve springs. The guideplates are "north" of the springs, from the rocker studs to above the pushrod holes.
[Modified by page62, 11:22 AM 5/14/2003]
