Pushrod guideplates on an L82?
Old May 13, 2003 | 06:15 PM
page62's Avatar
page62
Default Pushrod guideplates on an L82?
I removed one of my valve covers in preparation for adjusting the valves. And lo! I beheld a set of pushrod guideplates.
Correct me if I'm wrong here, but a stock '79 L82 doesn't have guideplates. I can't see any markings on the rockers, so I'm not sure what their ratio is.
Any guesses as to what's going on here?
Old May 13, 2003 | 06:18 PM
Greg's Avatar
Greg
Just another Corvette guy
Default Re: Pushrod guideplates on an L82? (page62)
What's the cast number on the head?
Old May 13, 2003 | 06:20 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Pushrod guideplates on an L82? (Greg)
If your asking if they are stock, no - they are not (at least that is what I have been told)
try and I.D. the rocker arms to find out what ratio you have. Maybe compare yours with a known 1.6 or 1.5 to see which one it is.
I wonder if someone machined your stock heads and are using 1.6 ratio arms on them.
[Modified by BSeery, 5:34 PM 5/13/2003]
Old May 13, 2003 | 06:21 PM
BSeery's Avatar
BSeery
CI 6-7-8 Veteran
For when you find the casting number of the cylinder heads ---- http://www.chevytalk.com/tech/engine/SBC_Heads.html
Old May 13, 2003 | 06:22 PM
page62's Avatar
page62
Casting number (I think) is 462624. There is also a big "GM" cast on the head.
Old May 13, 2003 | 06:35 PM
page62's Avatar
page62
Default Re: Pushrod guideplates on an L82? (BSeery)
This casting number is the stock number. Still a numbers-matching engine, despite some apparent tweaks...
[Modified by page62, 5:45 PM 5/13/2003]
Old May 13, 2003 | 06:42 PM
Roscoe's Avatar
Roscoe
On my 73 L 82 there are push rod guideplates. casting # 330545
Old May 13, 2003 | 07:02 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Pushrod guideplates on an L82? (Roscoe's C3's)
weird, 462624 heads have tiny pushrod holes, you won't need guide plates with those, unless someone hogged out the holes in the head.
Old May 13, 2003 | 07:08 PM
Tom73's Avatar
Tom73
I was under the impression that the L82s had guideplates.
tom...
Old May 13, 2003 | 07:11 PM
Pete79L82's Avatar
Pete79L82
Default Re: Pushrod guideplates on an L82? (Tom73)
My 79 L82 has guideplates.
Old May 13, 2003 | 07:13 PM
Twin_Turbo's Avatar
Twin_Turbo
look at the tiny slots for the pushrods.
no use for guide plates there
Old May 13, 2003 | 07:33 PM
BSeery's Avatar
BSeery
CI 6-7-8 Veteran
Default Re: Pushrod guideplates on an L82? (Twin_Turbo)
Wow !! Sounds like a lot of the L-82 guys are saying they have guideplates.
I was under the impression that no GM smallblock ever used them from the factory.
:lurk: :lurk: :lurk: :lurk: :lurk: :lurk:
Old May 13, 2003 | 07:37 PM
BSeery's Avatar
BSeery
CI 6-7-8 Veteran
Old May 13, 2003 | 07:39 PM
BSeery's Avatar
BSeery
CI 6-7-8 Veteran
462624 1976-87 1.94/1.50 & 2.02/1.60 76 CC Chambers
These are crack prone!
Old May 13, 2003 | 07:42 PM
Twin_Turbo's Avatar
Twin_Turbo
yes, they are the 76cc 1,94 x 1,5 thin casting open chamber design smog heads. Absolutely the worst head ever produced by GM. Restrictive, weak, poor chamber design,.. JUNK.
Old May 13, 2003 | 07:46 PM
BSeery's Avatar
BSeery
CI 6-7-8 Veteran
Don't beat around the bush.....
Tell us what you REALLY think !! :jester
I agree, late model cheap casting smog heads. A set of newer / better heads would be a good start if you want to build some HP.
Nice to know what the L-82's had on them for cylinder heads now. I am disapointed in GM for using this casting when there was much better to be had in the parts bin. I would expect this on a L-48 but not a L-82.
Old May 13, 2003 | 09:19 PM
dman535's Avatar
dman535
All L-82 motors came from the factory with 2.02/1.60 valves,screw in studs and guideplates. The castings are the same
To Pushrod guideplates on an L82?
Old May 13, 2003 | 09:24 PM
page62's Avatar
page62
Default Re: Pushrod guideplates on an L82? (dman535)
The good: large valves, guideplates
The bad: large volume smog heads
The ugly: junk castings, prone to cracking
:eek:
Old May 13, 2003 | 09:46 PM
PROSOUTH's Avatar
PROSOUTH
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
My '80 L-82 heads have the plates and screw in studs but they do not have the 202 valves they are 1.97. JIM
Old May 13, 2003 | 10:26 PM
toyvet1's Avatar
toyvet1
I have a original 79 L-82 had it came with guideplates.
