Anyone have a source for these? Also need some urethane mounts. Don't want to order from Ecklers or similar because of their insane international handling.
actually I want aluminium but the alu ones are longer than the later models making the body sit too high. I don't care about rattles, my car will be uncomfortable. I am not a fan of rubber at all. I have poly everywhere else.
Hey TT - I bought all my body bolts at a local hardware store. 7/16" coarse
grade 8. The only thing special about the stock bolts is the tapered end for
easily finding the hole. I found little trouble getting a regular bolt to thread in
without too much fussing. I am using the poly mounts from ZIP. I hear you
on the international shipping/duty. The mounts themselves were only $45.
If you want solid mounts, then some 2"x2"x1" thick Aluminum stock with a 1/2" hole in the
center would work. The 70 had the original AL mounts in it. They were
corroded to hell - so I went with poly cushions. The AL mounts just require
a big thick washer on the top (grade 8 if available).
I forget the length that I bought for the bolts. I'll measure them tonight - but
the length will depend on the cushion/block that you use.
BTW - I think you got it backwards. The original AL mounts for early C3s are
about 1/2" thick. These would lower the body a bit.
