Pertronix / dist problem solved
Old May 15, 2003 | 10:41 PM
conway62's Avatar
conway62
Default Pertronix / dist problem solved
I had removed my dist to remove some end play. When I put it back in, no spark condition appeared. Its an original points dist but I had a pertronix lobe sensor intalled. No matter what I tried it would not fire up. Tested everything. The pertronix for no reason just stopped working. After testing everything I installed a new set of points and condensor. Fired right up and it has more power that it ever had with the Igniter installed. Many thanks to Lars for clueing me in about the dimple on the timing gear. By By Pertronix.
Old May 15, 2003 | 11:34 PM
PRNDL's Avatar
PRNDL
When they fail, they go suddenly and completely. Anyone with pertronix should suspect the unit FIRST if their car fails to start. Unfortunately, it is all too common to start troubleshooting and waste a bunch of time, effort, and even $$ before you figure out what the problem is.... Am I out of gas? Is it flooded? Fuel pump out? :)
BTW, I had a similar thing happen to me. Fortunately did not waste a whole bunch of time troubleshooting. Put the points back in and like you, byebye pertronix. :) MJ
