Shift Kit?
Old May 24, 2003 | 06:42 PM
SCVetteGuy's Avatar
SCVetteGuy
Default Re: Shift Kit? (QuickVet)
That's great. Especially since its cheap. My trans is TH-350 right?
And it'll be great to feel the shifts!!! Sometimes I can't tell when it shifts from 1-2. :yesnod:
[Modified by SCVetteGuy, 5:44 PM 5/24/2003]
Old May 24, 2003 | 08:47 PM
jerryp58's Avatar
jerryp58
Default Re: Shift Kit? (SCVetteGuy)
I got mine at the local parts store.
Before you buy, find out if you have a TH350 or TH350C so that you get the correct kit. I'm not sure how you identify the C versus non-C externally. I think it has some electrical wires inside the pan though that run a lock-up converter. Others with the C may be able to offer more info.
Old May 24, 2003 | 10:37 PM
QuickVet's Avatar
QuickVet
Default Re: Shift Kit? (jerryp58)
:confused: Hmmm.. I have never heard of such a thing
Old May 25, 2003 | 12:07 AM
DP77Vette's Avatar
DP77Vette
St. Jude Donor '10
You can get the B & M at Advance right here in your town. Rick's transmission rebuilt my tranny and drilled the valve body which does about the same as a kit, so they say.
Old May 25, 2003 | 12:16 AM
phxraptor's Avatar
phxraptor
The 350C came out in 81, it is the electronic lockup version of the 350. Same trans as far as I know as other 350's except for the lockup. :seeya
Old May 25, 2003 | 01:57 AM
desi's Avatar
desi
Installed one last weekend. I like it alot. Get one. But be prepared to spend a good part of the day installing it. And it's one of the messy jobs. A second pair of hands definitely recommended.
Good luck. :cheers:
Old May 25, 2003 | 09:20 AM
Yeller81's Avatar
Yeller81
Default Re: Shift Kit? (desi)
Make sure sure if you "C" or not . It does make a difference . I have a 81 and I do believe the C came out that year.
You wil need the TransPak if you have a TH350C.
I love mine and it is a B&M been in the car about a year and works great.
:steering:
Old May 25, 2003 | 11:03 AM
QuickVet's Avatar
QuickVet
Good luck. :cheers:
If i were you. I would have it installed. These things are easy to mess up. If that happens you have to tow it to the tranny shop and will cost alot more in the long run :smash:
Old May 25, 2003 | 11:57 AM
SCVetteGuy's Avatar
SCVetteGuy
Thanks for the info DP77Vette, its nice to see someone from Sparkle City. About the installation, I don't have much experience installing stuff, but my dad will of course be there doing most of the work. I'll talk to him about whether or not he thinks we can install it. Thanks for all the help guys. I won't be able to get it for at least a week though, my dad is gone to Fla. on vacation. But I'll tell you guys when I do get it! :cheers:
Old Jun 1, 2003 | 11:33 AM
SCVetteGuy's Avatar
SCVetteGuy
With the shift improver kit, and my stock L-48, will it chirp the tires?
Old Jun 2, 2003 | 01:05 PM
desi's Avatar
desi
My 74 L48 with auto chirps in second now.....but again, it depends if yours is tuned right.
Good upgrade. I recommend it.
Old Jun 2, 2003 | 01:22 PM
Glutamine83's Avatar
Glutamine83
i'm running about 300hp to the wheels, should I upgrade and get a shift kit??? will i see lower E/T's?
