Fuel Pump Question
Old May 19, 2003 | 06:19 AM
Mystery Machine's Avatar
Mystery Machine
Default Fuel Pump Question
My car is a bit hard starting and runs a bit rough until she warms up (~5 minutes or a few miles). I was wondering if it may need a larger volume (more powerful) fuel pump and/or larger diameter fuel lines. Currently it has the stock fuel pump and fairly small lines (3.8" I think). I have a mild engine (ZZ4) and a Demon 650 carburetor. Any thoughts?
Thanks! :thumbs:
Old May 19, 2003 | 07:29 AM
Fevre's Avatar
Fevre
Default Re: Fuel Pump Question (Mystery Machine)
Sounds more like a choke adj problem than fuel pump. Stock L-48 fuel pump and lines are good to I would guess 400 hp, my eng is probably in the mid to upper 300's with a stock pump and no fuel problems I can tell.
Old May 19, 2003 | 08:15 AM
Mystery Machine
Default Re: Fuel Pump Question (Fevre)
Yeah, I'm not more than ~350hp. What would it be with the choke though...it has elec. choke and it idles up high when it's cold and I pop the gas and it comes back down...that's normal right? Although, it does choke when the engine is still warm and I always thought that was weird...any thoughts on that? :confused:
Old May 19, 2003 | 09:40 AM
Fevre's Avatar
Fevre
Sounds like it is operating corretly but may need some adjusting. Try starting it cold and see how much by-pass there is (choke blades open). If there appears to be a lot try putting your hand over the carb and see if it helps. If no by-pass (or little) try pulling the choke closed a little.
What rpm does it initialy idle at when started? Think when cold it sould be about 1800-2000.
Old May 19, 2003 | 10:37 AM
Mystery Machine
Thanks!
I don't have a tach hooked up right now (HEI and mechanical tach don't jive) but ~2000RPM sounds about right. I'll try your suggestion.
To Fuel Pump Question
