Crossfire Injection question
Old May 19, 2003 | 01:08 PM
PB82CE's Avatar
PB82CE
Default Crossfire Injection question
Once again during a cruise yesterday after my car warmed up,
got a Check Engine light. Engine ran rough, and eventually went into
Limp Home mode, revving at around 2200 rpm.
Got home and shut the car down. After a few minutes restarted the engine and it was fine for a while, then Check Engine light again.
Any ideas???
:confused:
Old May 19, 2003 | 01:24 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Default Re: Crossfire Injection question (PB82CE)
Hey Peter how you doing?
What have you relaced so far....what codes are you getting....sounds like a senser is failing with heat and throwing you into limp home, O2 maybe?
Old May 19, 2003 | 02:06 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Crossfire Injection question (gq82)
yeah, pull the codes.. that will give an idea what to look for.
Old May 19, 2003 | 03:09 PM
PB82CE's Avatar
PB82CE
Hey Jerry and Twinnie,
I will have some codes pulled and let you know.
Could be 02 or possibly a heat sensor??
Where is the 02 sensor?? Can I change it myself??
Old May 19, 2003 | 04:22 PM
Twin_Turbo's Avatar
Twin_Turbo
It could be the coolant temp sender, the O2 sensor is in front of the catalytic convertre (there's purple a wire coming from it)
Old May 19, 2003 | 04:24 PM
gq82's Avatar
gq82
Peter the O2 sensor is (screwed?) into the exhaust pipe just past the cat if I remember correctly with one wire going to it, and yes you can change that out yourself. Get the GM replacement not a cheap sub.
To Crossfire Injection question
