Dremal Rotary Tool
Old May 21, 2003 | 09:16 PM
joe73vette's Avatar
joe73vette
Default Re: Dremal Rotary Tool (stickboy)
I use mine a lot. I got the 4' flexible shaft, too. Just remember to wait for it to wind down before putting it down on the kitchen table! Joe
Old May 21, 2003 | 10:31 PM
schrecke's Avatar
schrecke
Default Re: Dremal Rotary Tool (StingRay327)
I use the Rotozip. It comes with 1/8 or 1/4 in collet so you can use dremel bits/tips, router bits, or drill bits. With the flex shaft, there's nothing it can't do that the Dremel can. You can get an angle grinder attachment, a circle cutter, etc.... You can cut 3/4 pine in one pass, I don't think a Dremel will do that. However, if you're cutting pine boards to work on your car you've got other issues to deal with :)
Old May 21, 2003 | 10:44 PM
TheVin's Avatar
TheVin
I have one too,,,,it's the Bomb!
Old May 21, 2003 | 11:23 PM
ManFromEagle's Avatar
ManFromEagle
I'll tell you what's handy.
Take a Q-Tip and cut it in half. Stick it in the collet of the dremel and use it to clean nooks and crannies. I used it on my power window switches and those 30 year old switches look better than the reproductions.
Great little tool. :hurray:
