Adj pivot stud ?'s
Old May 20, 2003 | 05:42 PM
Fevre's Avatar
Fevre
Default Adj pivot stud ?'s
Who has welded and where, and who has used locktite and has it held up? Welding sounds bad in the long run, not a welding expert so might be wrong, cuz if the stud wears down you gotta get it out some how. All input appreciated.
Old May 20, 2003 | 08:36 PM
PROSOUTH's Avatar
PROSOUTH
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
Default Re: Adj pivot stud ?'s (Fevre)
Good observation Fevre, I had considered this myself as I will be installing my 5 speed that requires an elevated stud. I decided to use.......what else Stud Locker. Loctite Stud Locker definately will hold and can be removed after applying XXXX degrees of heat.
The weld is probably as permanant as you can get depending on how much is applied. A tack can be ground off but leaves a mess. Here is where overkill will make it forever. JIM
Old May 21, 2003 | 08:35 AM
Gordonm's Avatar
Gordonm
Default Re: Adj pivot stud ?'s (PROSOUTH)
Your not going to weld the stud into the bellhousing. You just weld the threaded nut to the stud so that the adjustable part is no longer adjustable. You can still remove the whole stud.
Old May 21, 2003 | 09:38 AM
Stefan69's Avatar
Stefan69
Default Re: Adj pivot stud ?'s (Gordonm)
:iagree:
The stud is from steel, the bellhousing is aluminum. No way to weld those together.
Stefan
Old May 21, 2003 | 10:22 AM
Fevre's Avatar
Fevre
I looked at the stud kit last night and now see what you guys are talking about. Looks like once you get your geometry right you can tack weld the stud portion to the base going in from the tranny side of the bellhousing. For some reason I thought the kit was a stud and a nut, as I am sometimes refered as. :jester
To Adj pivot stud ?'s
