K&N Filter
Old May 21, 2003 | 10:39 AM
Glutamine83's Avatar
Glutamine83
Default K&N Filter
what are your opinions on a K&N filter? should I keep the stock air cleaner assembly on my 79 and use a K&N, or buy a new air cleaner, rip off all the ducting, and get a K&N.........i'm looking for maximum airflow
Old May 21, 2003 | 10:49 AM
jimvette999's Avatar
jimvette999
Default Re: K&N Filter (Glutamine83)
K&N :yesnod:
Old May 21, 2003 | 10:59 AM
77Dream's Avatar
77Dream
I like my K&N very much. Getting a new intake should increase air flow, but I doubt your car would need more air. The reason I got a new intake was because it lookes way cool. :cool:
:cheers:
Old May 21, 2003 | 11:06 AM
Fevre's Avatar
Fevre
Sucking in more air that is super heated may not yeild any more power than sucking in less air that is cooler. You can use a K&N with your stock set up.
Old May 21, 2003 | 11:26 AM
isosceles's Avatar
isosceles
I dropped one in my stock air cleaner. I still use the snorkel setup. Believe it or not the valves on the air cleaner assembly still work :lolg:
Old May 21, 2003 | 12:42 PM
mvftw's Avatar
mvftw
Default Re: K&N Filter (isosceles)
I'm using a K&N on a stock L82 setup...works fine.
Old May 21, 2003 | 12:46 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Default Re: K&N Filter (mvftw)
When I went from a 3" X 14" paper filter to a 3.5" X 14" K&N the difference in power was noticable. :)
Old May 21, 2003 | 02:16 PM
Biker's Avatar
Biker
Default Re: K&N Filter (OHSIXX)
I use a K&N with the stock air cleaner assembly on my '81. The filter definitely makes a difference in performance.
I have a K&N on my Harley, too. When it's time to clean the filters, I do the both (car/bike) at the same time. I've found it's better to wash the filter and allow it to air dry overnight before spraying it with oil.
Old May 21, 2003 | 02:58 PM
pws69's Avatar
pws69
Default Re: K&N Filter (Biker)
Same - same!!
Love the K&N's
Old May 21, 2003 | 03:05 PM
bloodvette80's Avatar
bloodvette80
Default Re: K&N Filter (pws69)
Just my $0.02, I did a K&N, cap and rotor, new wires and plugs, rebuilt carb, and new intake gasket. After all done and said (over a period of 2 weeks) Huge difference. From a dead stop, when I drop the hammer, car will fishtail and peel, pretty good considering I THINK it's all factory other than headers.
Agent80 :iagree:
[Modified by bloodvette80, 8:30 PM 5/21/2003]
To K&N Filter
