Which c3??
Old May 23, 2003 | 08:35 PM
ac34me's Avatar
ac34me
2nd Gear
Default Which c3??
I am looking to purchase a c3 I like the 78-79-80-81-82 styles.
However, I am wondering what would be the best purchase. I understand that this is up to ones taste but I would like to know the pros and cons of each. I am looking for performance as well as reliability.
Old May 23, 2003 | 10:36 PM
Jack71's Avatar
Jack71
Default Re: Which c3?? (ac34me)
Those are not the preferred years for performance. You can get a clean, reliable car from that period at a very reasonable price though.
There are some neat cars from that period too. 78 pace car, 78 anniversary, 82 collectors are a few of the specialty models you should look into. Good luck!
Old May 23, 2003 | 11:18 PM
aharte's Avatar
aharte
Although none of those years have good performance stock, you can build up any of them pretty easily if your local smog requirements aren't too strict (except the 82. their poor excuse for a fuel injection system has almost zero upgrade potential without redoing most of the engine compartment).
The drivetrain is also weaker on the 80-82 models, so if you plan on lots of power, stay away from those.
Manual transmissions are rare, and get more rare on the newer models (none in 82).
Old May 24, 2003 | 01:09 AM
MN-Brent's Avatar
MN-Brent
Default Re: Which c3?? (aharte)
The later C3s are a little more civilized due to interior comforts. Power is down in stock form from the earlier models, but the cruising fun is still there.
I went with an 82 since I wanted the 700R4 OD tranny and the fuel injection for decent gas mileage. The CFI unit does have upgrade potential and you could explore that. Really it is a good drive it and forget it set-up. Some people convert over to TPI which would be fairly easy to do with an 82 since you have the 700R4 tranny already set-up.
The 80-82 body style is my favorite.
The 78-80s are normal carbureted and the 81 has a CPU controlled carb. You can get a 4 speed in the 78-81s but only automatic in 82.
Start looking at collectercartraderonline to see about pricing and condition of vehicle to familiarize yourself so when you go to buy, youll have a good idea of what to expect. Also you can go to terry rudy's CorvetteFaq.com and read the 3 section mechanics checklist summary in Just got your Vette for what to look for when looking at a C3 to buy.
Best of Luck. The search is alot of fun.
Brent....
Old May 24, 2003 | 01:21 AM
Crash Dummy's Avatar
Crash Dummy
St. Jude Contributor
To the forum....
When did GM go back to the mako shark rear end? My '80 had it. Was it in '79? I like the front ground effects that the '80 vette had along with the much more comfortable interior compared to the earlier C-3 styles. I can't say that the HP in '80 was any worse that all the way back to '74.
Old May 24, 2003 | 01:46 AM
SizzleChest's Avatar
SizzleChest
reliability only has to do with how well the previous owners took care of it. As far as performance, they are all in the same ballpark as each other unless of course if it's been modified at all. I wouldn't look into the pacecar unless you're buying it as a trophy car to take to shows. It's basically the same car with a different paint job and a spoiler (ya, there's some other minor things), but you pay a big difference in comparison to other 78s. If I was in the market for an "affordable" C3, I'd try and find a 73-74 vert.
Old May 24, 2003 | 10:04 AM
groovyjay's Avatar
groovyjay
79!!! No cons what so ever only Pros! ;) :lol: :cheers:
Old May 24, 2003 | 12:28 PM
djcwardog's Avatar
djcwardog
Check Mike Antonick's Corvette Fact Book, but I think the 1979 had the peak L-82 HP for the years you like. Find one of those with a 4-spd.
Old May 24, 2003 | 01:46 PM
fst_c3's Avatar
fst_c3
Default Re: Which c3?? (djcwardog)
this may help. It's the engine codes and options for all year C 3
http://www.thevetteheads.com/Dforms/.../1968info.html
Old May 24, 2003 | 04:03 PM
ac34me's Avatar
ac34me
2nd Gear
Thanks for all the info it is much appreciated. More comments are welcome. I think I may go for a 78 l82 4speed. I have seen a few out there for ~ $7,500
Looks like I just missed this nice 79
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2416551006
Old May 24, 2003 | 04:22 PM
SizzleChest
from what i've seen, there aren't too many l82 4spds around, even 4spd l48s seem to be uncommon. be sure to check the vin before you buy and be very careful buying on ebay.
To Which c3??
