Bubba found my rocker panel screws!!!!
Old May 25, 2003 | 01:32 AM
standup's Avatar
standup
Default Bubba found my rocker panel screws!!!!
A while ago I posted about Bubba using wood screws to fix my rocker panels......I always wondered what happened to the original screws......
I should have known that Bubba would put them right where I would find them.......
He used them to screw down a homemade shield that covers the power window control behind the door panel.......BTW, he didn't have enough so he used some wood screws too........
I'm so relieved knowing the original screws weren't lost :)
HANDY TIP: It's much less time consuming if you add "BUBBA" to the spellchecker in MSWord.......
Old May 25, 2003 | 02:41 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Bubba found my rocker panel screws!!!! (standup)
Yep, did that a long time ago... :smash:
Glad you found them, now what are you going to use to hold on the shield???
Old May 25, 2003 | 05:05 AM
standup's Avatar
standup
Default Re: Bubba found my rocker panel screws!!!! (Desertdawg)
I'm sure I'll find those screws somewhere soon....Bubba will show me the way....I may even find the original shield :)
Old May 25, 2003 | 06:53 AM
Paul L's Avatar
Paul L
I plead guilty to some Bubbaisms from time-to-time. Those rocker screws are prone to corrosion and seizing. Not pleasant if you ever need to get the rockers off for a paint job. I removed mine and replaced them with #8 (I believe!) SS machine screws and anti-seize. If I had taken the time to paint them black, they would look original.
Old May 25, 2003 | 07:03 AM
djcwardog's Avatar
djcwardog
Bubba has visited my car as well. I did a great Bubba job to salvage my left door window motor. It runs fine now and I delayed spending that $100 for a new one. The trick is to use Bubba smartly and not by accident! In other words, with Bubba aforethought!
Old May 26, 2003 | 09:01 PM
75 BBC Stingray's Avatar
75 BBC Stingray
I'm just starting on my project, and while cleaning out the junk stored behind the seats from the previous owner, I found a packet of machined stainless nuts designed to replace the stamped sheet-metal nuts originally used. The use of a nut would require the use of a machine screw. These nuts came in a plastic bag, with a set of instructions. No idea who sold these...
To Bubba found my rocker panel screws!!!!
