line locks
Old May 25, 2003 | 07:47 PM
hotbrakesracing's Avatar
hotbrakesracing
Default line locks
what is wrong when my line lok will not release front brakes? or with line lok electricly disconnected i push brake peddle down and still front brakes will not release.. if i crack the line coming from line lok to porpportioning valve the brakes release instantly
Old May 25, 2003 | 07:49 PM
bence13_33's Avatar
bence13_33
Default Re: line locks (hotbrakesracing)
Sounds like possibly a bad line lock solnoid?
Is this a new kit that you just installed or has it been in your car for a while?
[Modified by bence13_33, 6:50 PM 5/25/2003]
Old May 25, 2003 | 07:53 PM
hotbrakesracing
Default Re: line locks (bence13_33)
it has been in car for about a year with very little use until this spring
Old May 26, 2003 | 12:20 PM
norvalwilhelm's Avatar
norvalwilhelm
Do you have the lines on backwards? The in and the out mixed up. If you turn on the line lock under normal conditions and push the pedal after it is activated it should still allow the brakes to be applied.
Like Shane said it could be a bad solenoid.
Old May 26, 2003 | 08:00 PM
79Corvette02's Avatar
79Corvette02
:withstupid: On the bad solenoid- I think that's the problem, if its trapped the fluid.
Old May 26, 2003 | 08:33 PM
QuickVet's Avatar
QuickVet
Default Re: line locks (79Corvette02)
I would try rewiring it. if that doesnt work. its broken
Old May 26, 2003 | 08:37 PM
Jvette73's Avatar
Jvette73
If the solonoid is sticking, maybe some tapping on the side of it with wrench would free it up. If it keeps on stickin then I agree with the above. Bad solonoid.
Old Jun 3, 2003 | 11:30 PM
hotbrakesracing
Default Re: line locks (Jvette73)
thanks everybody--i took it out! doing it the old way
To line locks
