Dir. Signal Flasher
Old May 26, 2003 | 07:39 PM
coldwarrior2000's Avatar
coldwarrior2000
Default Dir. Signal Flasher
Hey Fellas,
New here, but have been enjoying your posts for a while now. My question is, on my 69 convertible, where the hell is the flasher for the turn signals? Is that it on top of the steering column behind the dash? Any help will be appreciated. Thanks.
Randy
Old May 26, 2003 | 08:31 PM
Larry B.'s Avatar
Larry B.
Default Re: Dir. Signal Flasher (coldwarrior2000)
It is in a clip under the passenger side dash pad about 2/3 of the way to the right at the bottom It shoud be a round plastic canister type with a capacitor soldered to it on the outside if it is the original.
Old May 26, 2003 | 08:50 PM
coldwarrior2000
That's interesting. Looking at the assembly manual, I thought it was on the driver's side. Well, if you don't mind my asking, what is it that's mounted on top of the steering column then? There are 2 pink wires, one routes to the fuse panel, the other has a female connector that I haven't figured out where it goes. There is also a purple wire that leads back to the fuse panel. BTW, thank you for your reply.
Randy
Old May 26, 2003 | 09:01 PM
Larry B.'s Avatar
Larry B.
The thing on top of the steering column is the ignition switch. There is another flasher on the fuse block but that is the emergency flasher.
Old May 26, 2003 | 09:32 PM
coldwarrior2000
Default Re: Dir. Signal Flasher (bluevetteman)
No kidding. I really do appreciate the info. I knew the flasher on the fuse box was for the hazard lights, but couldn't find the turn signal flasher. I spent about 4 hours Saturday looking for it. One more thing, can you point me in the general direction direction of the wiper relay? If I can possibly answer any questions you might have, please email me. Thanks again.
Old May 27, 2003 | 06:24 AM
Larry B.'s Avatar
Larry B.
The wiper relay is not fun to get to. I assume you mean the electrical relay. It is on the back of the tachometer.. There are no new ones available but there is an article on how to rebiuild them at http://www.corvettefaq.com along with a lot of other helpful stuff.
[Modified by bluevetteman, 6:26 AM 5/27/2003]
Old May 27, 2003 | 09:05 AM
flynhi's Avatar
flynhi
BVM,
Do you recall how many wires and what color wires connect to the flasher?
I assume they are the same on my 71.
Old May 27, 2003 | 01:45 PM
coldwarrior2000
According to the wiring diagram I have, there should be a pink and a purple wire connected to the flasher. I'll let you know for sure after I find it Saturday
To Dir. Signal Flasher
