Car Won't Start-????????????????????
Old May 27, 2003 | 10:19 AM
79Corvette02's Avatar
79Corvette02
Default Car Won't Start-????????????????????
I went to start up the car today after the winter. I jumped the battery, and it turns over, but it won't catch. The distributor/wires look fine, the timing should be good. I'm afraid I have some bad fuel in the carb, or it's all gummed up. How do I drain the fuel out of the carburator to get newer, fresher gas in there? Also, I took off my valve covers, and put them back on-the gasket looked fine, but do I need to replace it everytime I take the covers off? :confused:
Old May 27, 2003 | 10:24 AM
BB wowbagger's Avatar
BB wowbagger
Default Re: Car Won't Start-???????????????????? (79Corvette02)
Just squirt some fresh gas down the carb and see if it run on it..If it does,emty the tank and fill up with some fresh gas.. :smash: :cheers:
Old May 27, 2003 | 04:22 PM
79Corvette02
So just aerosolize some gas straight down the barrels of the carb and into the intake manifold?
Old May 27, 2003 | 04:35 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
You can just dump a small amount in - no need to aerosolize (that's a new word for me).
If it's bad gas, it will start (even if for a very short time) by dumping a small amount in the carb.
I assume you've checked for spark and all of the standard stuff?
To Car Won't Start-????????????????????
