'79 Speedo cable
Old May 27, 2003 | 12:39 PM
Blackened 79's Avatar
Blackened 79
Default '79 Speedo cable
I've got a bouncing speedo needle (and it's off by 5 MPH or so) I see an 'upper' and 'lower' cable listed in the catalogs...which do i need, and can the end that attaches to the gauge fit thru the firewall grommet ?
Old May 27, 2003 | 01:57 PM
Stewart's74's Avatar
Stewart's74
Default Re: '79 Speedo cable (Troublemaker 71)
Why dont you try greasing the cable?
Old May 27, 2003 | 02:18 PM
coldwarrior2000's Avatar
coldwarrior2000
Default Re: '79 Speedo cable (Stewart's74)
I just bought a new one piece cable for my 69. The speedo still doesn't work, but it will bounce occasionally. I know the cable and speedometer are good, so I figure either I don't have the cable pushed all the way into the tranny speedo gear or the gear needs to be replaced. And that's a ****** to get to.
Old May 27, 2003 | 03:51 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: '79 Speedo cable (coldwarrior2000)
If your 79 has cruise you may try disconnecting the cable at the cruise transducer and turn the cable with a drill and see if the speedo still bounces. No bounce=the upper cable is good. Disconnect the cable at the tranny and try the same as above. It could also be the cruise transducer itself.
To '79 Speedo cable
