GRAPHIC ADHESIVE REMOVAL??
Old May 27, 2003 | 04:28 PM
TJKirby82CE's Avatar
TJKirby82CE
Default GRAPHIC ADHESIVE REMOVAL??
I am removing the Graphic from the hood of my car. Under it will be some adhesive still stuck to the clear coat. What should I use to remove it that will not damage the paint?-TK
Old May 27, 2003 | 04:51 PM
Road Racer's Avatar
Road Racer
Default Re: GRAPHIC ADHESIVE REMOVAL?? (TJKirby82CE)
Bug and tar remover, they sell it at autoparts stores. or film cleaner or rubbing alcohol.
Old May 27, 2003 | 04:58 PM
Gator81's Avatar
Gator81
:iagree: I think I'd try the bug & tar stuff first, since you know it will be gentle to the paint. If that doesn't cut it, you might try 3M Weatherstrip Adhesive Remover, sold at stores that sell paint & bodywork supplies. Good Luck! :seeya
To GRAPHIC ADHESIVE REMOVAL??
