car wont start.....
Old May 30, 2003 | 10:46 PM
ykp53's Avatar
ykp53
Default car wont start.....
i drove some errends to day and the car was running fine, but when i got home i thought i would adjust my valves since they were making a little noise and i cant leave well enough alone. i removed the valve cover turned the car on and started to adjust the back drivers side exhaust valve and the car died. i have not been able to get it started yet. not even an attempted start. i thought maybe it wasnt getting enough fuel so i pumped it a few times and still no luck. then i thought since it was sitting on a pretty good slope maybe it had flooded itself so i left it alone for a few hours and tried again with no luck. i then tried spraying starter fluid but it still would not even attempt to start. any ideas or tips? how can i tell if i am getting a spark with out shocking my self? could it be the distributor? i did feel that the coil was warm after my repeated attempts at starting.. i dont know if that will help... thanks for any advice..
where is my sig. picture??????
[Modified by ykp53, 9:47 PM 5/30/2003] :confused:
Old May 30, 2003 | 10:59 PM
71coupe's Avatar
71coupe
Default Re: car wont start..... (ykp53)
You can get one of those special spark plugs with the clip on it from Sears. I keep mine in the car in case I have engine troubles.
How far did you get on the valve adjustment before it died? I'm assuming that you had it idling and you adjusted 1 valve and it died?
Old May 30, 2003 | 11:08 PM
ykp53's Avatar
ykp53
Default Re: car wont start..... (71coupe)
i losened the first one and was in the process of tightning it back down when it died. but yes it was running fine before, i did get it pretty hot if that matters(+230).
Old May 31, 2003 | 02:26 AM
R. Bruno's Avatar
R. Bruno
To check for spark I use the old Bubba method. Pull a spark plug wire and put a phillips head screw driver into the boot. Hold the screwdriver very near something metal, like a valve cover and crank the car. You should see a spark jump between the screwdriver and the valve cover or similar ground. (Keep your hands off the shaft of the screwdriver.)
If you don't have a helper, you should be able to lean the screwdriver against something in the engine compartment and watch for a spark when you crank the car. If you are brave and want to know for sure whether you have spark, hold the screwdriver shaft and crank it over- this is the method Bubba prefers. :D
Old May 31, 2003 | 10:08 AM
ykp53's Avatar
ykp53
Default Re: car wont start..... (R. Bruno)
will a timming light register when you turn the car over? if so than im not getting any spark. what should i check first?
Old May 31, 2003 | 03:50 PM
71coupe's Avatar
71coupe
Dude - do yourself a favor, get a spark tester for $5.00. See photo:
You can put it on the end of the longest plug wire & clamp it to a ground in a position to see it while you crank over the motor.
You can get one of these at any parts store. I guess you could try to use a timing light, but I like to see and actual spark. It may be hard to judge the strength of the spark thru a timing light.
Old May 31, 2003 | 04:22 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
:iagree: You can knock the fool out of yourself with 40kv. Ask me. It went through my elbow to the truck when checking it. I had hold of the screwdriver handle too. BTW, I knew I had spark for sure. :jester
Old Jun 1, 2003 | 02:41 PM
R. Bruno's Avatar
R. Bruno
Default Re: car wont start..... (Eddie 70)
Spark tester? I didn't know there was such a thing! Oh well, at least I saved on electro-shock therapy all these years. :jester
Old Jun 1, 2003 | 05:17 PM
isosceles's Avatar
isosceles
Check to make sure you didn't knock a wire loose around the dist. Check coil wire and all wires that provide power to coil.
Or the ground strap. Mine connects to the right side valve cover bolt. I had to reconnect it while I was adjusting my valves. Without it connected my car would not fire whatsoever.
To car wont start.....
