EVANS COOLING SYSTEM
Old May 30, 2003 | 11:45 PM
silver79's Avatar
silver79
Default EVANS COOLING SYSTEM
JUST GOT 4 GALLONS OF EVANS COOLING FLUID I WILL HAVE TO FLUSH ALL THE WATER OUT OF THE BLOCK AND THE RAD AND REPLACE WITH EVANS. I WILL LET YOU KNOW HOW IT WORKS. ANY OF YOU USING THIS PRODUCT?
Old May 31, 2003 | 12:39 AM
flynhi's Avatar
flynhi
Default Re: EVANS COOLING SYSTEM (silver79)
check with Zwede
Old May 31, 2003 | 11:01 AM
Red73's Avatar
Red73
I've used it for the last 5 years without a problem. My engine temps are between 180 & 190.
http://www.evanscooling.com/main21.htm
Old May 31, 2003 | 01:25 PM
flynhi's Avatar
flynhi
Default Re: EVANS COOLING SYSTEM (Red73)
Red73,
Aside from the improved cooling, have you seen any other benefits advertised by Evans?
Old May 31, 2003 | 01:38 PM
69L68's Avatar
69L68
Please let me know. I thought I had all my cooling problems licked until the other day. I tried to run out to Riverside Ca the other day. It was non and 106 degrees outside and I ran it pretty good. Dont know if I was just asking to much or what.
Steve
Old May 31, 2003 | 08:11 PM
silver79's Avatar
silver79
Default Re: EVANS COOLING SYSTEM (69L68)
I WILL LET YOU KNOW THIS WEEK MY CAR RUNS AT 220 AL THE TIME WITH A 180 OR 160 DEGREES THERMOSTAT I AM GLAD TO SEE THAT REC73'S RUNS AROUND 180-190 AT 220 IT ALWAYS PINGS DURING PART THROTLE. I AM ALSO GOING TO INSTALL A NOS KIT THIS WEEK.
To EVANS COOLING SYSTEM
