Screaching Noise
Old May 31, 2003 | 08:48 PM
79C3's Avatar
79C3
Default Screaching Noise
Hi All. Over the past few days I have noticed a screaching noise when accelerating quickly in first gear. The noise, which sounds like an old brake pad grinding into the rotor, lasts about a second before it shifts into second. The first couple of times it happened I thought it was the horn from some small car. Any ideas? This is on a 79 L-48 with auto. Engine is original and was rebuilt about 25,000 miles ago. Fluid on the original tranny, which was inspected and declared OK during the rebuild, looks pink and full as well. Otherwise tranny is the way it was when it rolled off the line. 160,000 miles on the car. Thanks for any input!
Old May 31, 2003 | 10:46 PM
79MakoL82's Avatar
79MakoL82
Default Re: Screaching Noise (79C3)
I haven't a clue, but I'll bump you up to the top. I assume this noise is coming from the tranny. When you said screaching, the first things that came to my mind are belts, A/C compressor, pumps, etc. But if it only happens in first and is coming from the area of the tranny.... :confused:
ttt
Old Jun 1, 2003 | 12:16 PM
Jvette73's Avatar
Jvette73
Default Re: Screaching Noise (79MakoL82)
i too ws gonna say check the belts
Old Jun 1, 2003 | 01:05 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Default Re: Screaching Noise (Jvette73)
:iagree: Esp the ac comp
Old Jun 1, 2003 | 04:18 PM
79VetteMike's Avatar
79VetteMike
I think it's the belts also. Check step by tep. The first thing I would do is turn the steering wheel from one side to the other. Then check the a/c at different engine rpm's. Make sure that you have all of the brackets on your belt driven accessories. If everything looks good, spray some belt dressing on the belts-I just use WD-40. If the belts still squeak, then I'd check to see if the screaching happens at the same rpm in other gears.
Old Jun 1, 2003 | 04:19 PM
79VetteMike
Default Re: Screaching Noise (79VetteMike)
[QUOTE]I think it's the belts also. Check step by tep. The first thing I would do is turn the steering wheel from one side to the other. (maybe the power steering fluid is low)
Old Jun 1, 2003 | 04:23 PM
Jvette73's Avatar
Jvette73
Also many people dont realize it but the compresor operates with the climate controll in the defrost position. when the compressor is running there is a greater drag and the belt is more likely to slip. Just mentioning this in case the noise is happening with the a/c on or when the defrost pasition is selected.
Old Jun 2, 2003 | 12:32 AM
79C3's Avatar
79C3
Thanks everyone. I will check the belts and AC. I just needed some reassurance this wasn't some well-known issue to the old C3 tranny.
Old Jun 2, 2003 | 03:26 AM
BB73Chris's Avatar
BB73Chris
Rev it up in park (with the AC however you have it when it screeches) to the rpm where it makes the noise (quickly, cause if you just ease up there it might not do it). If it still makes the noise, you've totally eliminated the tranny.
Old Jun 2, 2003 | 07:37 AM
Stephen Irons's Avatar
Stephen Irons
2024 C3 of the Year Finalist - Unmodified
Hate to put a downer on this thread. Check the belts, that would show up with the car standing still when revved hard.
But, it sounds very similar to the noise that mine made when he first gear in the trans needed some work..... Sounded like the exhaust of something metal is hitting, or scraping along the ground under hard acceleration? Need new "clutch bands". Also might be worth looking at the fan shroud. If the fan was catching that under acceleration it could be engine mount related?
Old Jun 2, 2003 | 07:47 AM
Neo Fender's Avatar
Neo Fender
It's the tires doooood!
vroom, vroom.
Old Jun 2, 2003 | 10:48 AM
American Boy's Avatar
American Boy
Another thing to check is the engine rubber support. I had a similar noise when accelerating and an engine rubber mount had seperated. The noise was from the fan hitting the shroud. To check this, open your hood, put it in gear with the brake and accelerate. If it's the problem, the engine will lift.
Stephan
Old Jun 2, 2003 | 10:55 PM
79C3's Avatar
79C3
Wow, great great advice guys. Thanks much! I'll let you know what I find out. Thanks again.
Old Jun 2, 2003 | 10:59 PM
79C3's Avatar
79C3
Default Re: Screaching Noise (Neo Fender)
vroom, vroom.
Ha! Good One Neo! The tires! :lolg:
To Screaching Noise
