Anyone had experience with a BB 396 (402)?
Good luck with El Camino search!
Regards,
My older brother had a `64 GTO, 325hp 4 spd, that couldn't do better than low 15's. He was impressed by my SS but, having just bought his first house, his budget was tight. He special ordered an SS with one option, the radio. Standard 325hp, bench seats, Saginaw 3spd, standard 3.31's, no posi, no nothing. First time out it ran 14.4's. His best time was 14.20. By chance, that 14.20 was on a run against a brand new 426 Hemi Roadrunner and a driver that probably needed a lot more practice with it. The Hemi ran a 14.26 but was much slower out of the hole and that difference looked much greater to those watching.
The main difference between the 325hp and the 350hp engines were the cam and, on the earlier ones, the 350hp versions used a 585 Holley instead of a Quadrajet. Heads, compression, etc. were the same.
[Modified by Tex71BB, 10:09 AM 6/4/2003]
That's a good question, OatBoy! I could buy a 396 with the comfort of knowing I could always stroke it, if I want more. The 396 has been rebuilt, so it should have a .030 or .060 overbore. With a 4" crank, that would result in a 434 or 440 (instant Mopar?). I assume you have to change the entire reciprocating assembly, though, so it would probably be easier to just swap in a 454 and get a few more cubes. Decisions, decisions....
One was a 396/375 with two sleeves in it, a bunch of helicoiled head bolts, an L-88 cam, stock rectangular ports, a Weiand tunnel ram with 660 center squirters. It ran mid-high 10's in a 4 speed 3400 lb Nova pulling wheelies in second gear and turning 7500+ rpm regularly.
The lo po versions were all based on 10.25 cast pistons, oval port GM iron heads, several different hyd flat tappet and solid flat tappet cams, Holley Strip Dominator intakes, 750 DP Holleys and 1 3/4" headers. They revved in the 6200-6600 range and ran high 11's/lo 12's in Nova's and Camaro's.
One was in a '69 SS396 Chevelle. It was a 325hp one with a GM marine .500 lift cam, cast iron intake, and Q-jet with 1 3/4" headers. It ran low-mid 13's with a T-400, stock converter and 3.36 gears with 9" slicks. Ran many, many runs against a buddy's SS454 Monte Carlo. He had more cubes, less compression, same cam and no headers. We ran eyeball to eyeball on every run.
I think with todays technology in cams, you could easily build a daily driver 12 sec 396 El Camino with GM iron heads. Put in a good cam, pocket port the heads, install headers, RPM air gap intake and a 750 Holley and you're home free. I doubt gas mileage will be great unless you install a 200R4 behind it. I wouldn't use a 700 R4.
The 396 is an often overlooked motor that can make lots of power. I wouldn't spend a ton of money on one, but if I got one cheap, I'd do a quicky rebuild with a few hotrod parts and have a blast!
JIM
