Removing Tach Needle? How To?
Old Jun 3, 2003 | 03:54 PM
cor72vette's Avatar
cor72vette
Default Removing Tach Needle? How To?
I'm replacing my tach in my 72. The face on the original tach looks better that the replacement. So, i want to swap them. How do you remove the needle so the face can be removed. I don't want to damage it. This forum rules! Thanks!
Old Jun 3, 2003 | 04:02 PM
mrvette's Avatar
mrvette
Default Re: Removing Tach Needle? How To? (cor72vette)
OK, first off, wash your hands/finger VERY well, NO oils.....then grab with index finger and thumb and wedge your finger/thumb tips up under the needle next to the card...IF you have longer fingernails you might want to do a piece of paper next to the compass card....pull UP as hard as you can...
NOT pulling on the needle--oppoisite balance end-tip.....just the middle round section, sometimes it takes a bit of force and gets uncomfortable....
I have done it a LOT...
unfortunately....
have FUN!!!
this is all best done on a kitchen table with good to great lighting...
GENE
75Rag's Avatar
75Rag
Assuming yours is the same as my '75, it is press fitted onto the shaft so grasp firmly and pull gently. I found it helped to "rock" the tach needle side to side between my fingers as I pulled.
Old Jun 3, 2003 | 10:55 PM
Bobbyg75's Avatar
Bobbyg75
Default Re: Removing Tach Needle? How To? (75Rag)
:iagree: rock side to side - GENTLY!
To Removing Tach Needle? How To?
