Interior paint
Old Jun 3, 2003 | 05:54 PM
C1C2C3whatsnext's Avatar
C1C2C3whatsnext
Cruising
Default Interior paint
I need to touch up the steering column, where I installed an aftermarket wheel. The hub doesn't match the interior paint. The paint code is 592, I beleive that is doeskin.
Any off the shelf paints match this?? :confused:
Old Jun 3, 2003 | 06:05 PM
OddBall's Avatar
OddBall
Default Re: Interior paint (C1C2C3whatsnext)
I don't have a doeskin interior; mine is off-white.
However I did find a perfect match for it at Advance-Auto. AND..
I did see a doeskin color.
Also, I should note:
Although I wasn't expecting much in the way of quality, I was
surprised. After painting that soft flexible cover for the center console
where the parking brake sets; I wadded the cover up to see if the paint
would crack. It held up great.
I learned real quick though, to lay down a lot of thin layers of paint. If you
don't it'll want to run.
Hope that helps.
Lots-a-luck
