HEI Conversion?
I kept thinking and thinking and finally decided to put the original Numbers matching 427 in storage and install a slightly modded 454. I got block, heads and crank. Now it's off to machining and then I'll start putting this thing together. Which made me think: Is there a way I can use a HEI dist?
What happens to my tach-drive?
Thanks :seeya
Stefan
[Modified by Stefan69, 2:45 PM 6/4/2003]
[Modified by bb69, 4:44 PM 6/4/2003]
[Modified by Todbo, 5:41 PM 6/4/2003]
You also would have to replace your tachometer with a electric one... Used 75 - 77 tachometers (electronic and perfect fit) are around $75....
HOWEVER: If I look at the MSD equipment they also have those very very :cool: Crank-triggers. I know you don't need them if you don't build an all-out-*****-to-the-wall race car... But just thinking out loud- what would it take to make the stock tach work with that?
Can I just leave my stock-dist in there and disconnect everything?
Thanks!:cheers:
Stefan
For my dist upgrade im using my stock points dist with tack drive and I have it converted to electronic with petronixII and 50,000 volt canister coil. its served me well and the total conversion including coil cost about$150
Dave Ray
(562) 699-6949
(562) 695-9199 Fax
sparkman451@earthlink.net
Dave's Small-Body HEIs
11605 Waddell Street
Whittier, California 90606 http://www.DavesSmallBodyHEIs.com/
Thanks!:cheers:
Stefan
IMO, yeh, I hear you about hating freaking DASH boards,.#*%&%^)@&*!@&%@@@@ myself on them....BUT, you gotta consider the car is ~30 years old, so it's time to grin and bear it.....take the damn thing apart, and do it all correctly ONE time hopefully, tach, ohaul speedo head, redo lightbulbs, might make a harness connector so you can plug the bulbs in while it on the bench then have just ONE plug for all the lights in the dash panel....for future use...
same with center gauges console.....
course, then again, 2 winters ago on my '72 there...I just redid the entire wiring for engine and interior....tore the harnesses apart and found all sorts of terror in there, some from the factory, but splices even I did not existed...definately NON factory....I dunno, I just feel better about my own freaking soldered and insulated wiring, no crimp connections everything soldered, even the plugs....like the military would do, not necessarily their expensive grenade proof connecters, but using say Radio Shak 'MOLEX' style white connectors....which are great for LO current crap, like signals, small loads and light bulbs.....nothing like power windows, etc that have decent currents involved....those I all hard wire....
GENE
