Dyno today
Old Jun 5, 2003 | 12:28 PM
randy72's Avatar
randy72
Default Dyno today
Dropped the car off last night...Hoping to be over 300 RWHP.. It was 290 last year, I've since done some port work, added an H-pipe and upgraded to an MSD ignition.
Old Jun 5, 2003 | 12:32 PM
Glutamine83's Avatar
Glutamine83
Default Re: Dyno today (randy72)
what do you have done to the engine already?
Old Jun 5, 2003 | 03:11 PM
randy72's Avatar
randy72
Default Re: Dyno today (Glutamine83)
383, Lt1 intake and carb. ,Hyd. roller (509/528, 222/230), ported Lt1 heads, 10:1 compression, balanced, 2.5 " exhaust w/2.5" manifolds.
Old Jun 5, 2003 | 03:15 PM
Fevre's Avatar
Fevre
That is almost exactly what I plan on building, already have the same cam and most of the stoker parts. Might take the new LT-1 Intake off my Formula to use in the vette. How is the torque with that?
[Modified by Fevre, 2:15 PM 6/5/2003]
Old Jun 5, 2003 | 03:17 PM
Corey_68's Avatar
Corey_68
Default Re: Dyno today (Fevre)
You should have no problems making 300RWHP+.
Post them when you get them. :cheers:
Old Jun 5, 2003 | 08:59 PM
QuickVet's Avatar
QuickVet
Default Re: Dyno today (Corey 68)
whadcha put down :smash:
Old Jun 5, 2003 | 09:13 PM
69shark's Avatar
69shark
From: Godspeed Mikey Hogsmak Invitational Spring Skyline Drive Corvette Cruise
Cruise-In I Veteran
Cruise-In II Veteran
:cool: Randy :cheers: I just finished my 383 3 weeks ago and had it dyno'd before putting it in the vette(in progress) and I got 473tq and 436hp at the crank. I dropped off the tranny yesterday to have it checked out. I shoud be ready to drive by next weekend. :chevy
Old Jun 5, 2003 | 10:05 PM
Clink69's Avatar
Clink69
I am suprised you weren't over 300RWHP already. You should be at 325 RWHP with that setup...
Old Jun 6, 2003 | 12:02 PM
randy72's Avatar
randy72
Default Re: Dyno today (Clink69)
It's a 72 Lt1 intake, not a late EFI Lt1. I have a problem, but don't know where. I was down 40 hp on the first pull (245hp) and was super rich. Jet change got it up to 275, but that's still 10 less than last year. I was hoping for 305-310. I think the valves are floating, will know more next week....
Old Jun 6, 2003 | 12:06 PM
randy72's Avatar
randy72
Fevre,
It's torquey. pretty lame below 2,000 RPM, but I've got a 4 speed and 3.70's so it doesn't spend much time down there.
:jester
Last year, it was 340 tq. @ 3500 peak. 300 min. from 2500-4900. It's down about 10 ft.lbs. across the board.
Old Jun 6, 2003 | 12:10 PM
Fevre's Avatar
Fevre
Fevre,
:jester
Same why my 350 acts with that came, lame until about 2500 then hold on! Ya sounds like you got a problem, done a comp and leak down test? How's your timing and adv curve?
Old Jun 6, 2003 | 12:20 PM
randy72's Avatar
randy72
Timing and advance curve is fine....It's at 35 degrees all mech.. The vac. is plugged off( we had it at 38, but made more power where it's at).....Don't remember what RPM it's in by, but it's before 3000.
Have not done a compression and leakdown test yet...Motor is barely a year old, so I don't think it's an issue, but it will be checked along w/ the valve springs. It's done at 5,000 and the power dips right after peak then picks back up, that's why we're thinking valve springs. This cam should pull to at least 5500 in this engine. I'm peaking at 4800. :confused:
[Modified by randy72, 11:21 AM 6/6/2003]
Old Jun 6, 2003 | 12:28 PM
Fevre's Avatar
Fevre
What carb you running? Almost sounds like your sec aren't opening all the way. :confused:
Old Jun 6, 2003 | 01:15 PM
randy72's Avatar
randy72
LT1 Holley 780...They're opening all the way.
Old Jun 6, 2003 | 05:27 PM
QuickVet's Avatar
QuickVet
can you post the sheet for us to evaluate?
Old Jun 9, 2003 | 09:37 AM
randy72's Avatar
randy72
Default Re: Dyno today (QuickVet)
No access to a scanner. We checked the springs yesterday and they have less than 100 lbs. at the seat. Should have new ones in on Wed.
Old Jun 9, 2003 | 09:56 AM
Fevre's Avatar
Fevre
Looks like you have found your problem. :cheers:
To Dyno today
