radiator support
Old Jun 6, 2003 | 10:57 AM
KWIL's Avatar
KWIL
St. Jude Donor '12-'13
Default radiator support
does anyone know of a cheap source for a radiator support for a 76 early design? (I think a 69 to 76 with a/c is the same support).
I have had no luck finding a used one (posted in c3 parts wanted) and cant see paying around $300.00 for a new one that is thinner steel than the original. :eek:
anyone?
[Modified by bhblue80, 3:57 PM 6/6/2003]
Old Jun 6, 2003 | 11:01 AM
Tominator's Avatar
Tominator
Default Re: radiator support (bhblue80)
I hear you, paid close to $400.00 for mine. :eek:
Old Jun 6, 2003 | 12:31 PM
One Bad 74's Avatar
One Bad 74
I got lucky and found mine on Ebay. It was about $100 and rust free. You just never know what you're gonna get on Ebay, could have just as easily been a peice of junk.
Someone may have more detail, but I don't think they are the same for all those years.
Old Jun 6, 2003 | 12:44 PM
mapman's Avatar
mapman
I feel your pain! My (new) replacement was $$$ as well. As prone to rust out as these supports are, I would be very careful with buying used.
There was a thread many months ago where a guy had fabricated a new SS support to go with his new aluminum radiator. It looked great, but I don't think it was cheap.
Old Jun 6, 2003 | 01:44 PM
mrvette's Avatar
mrvette
I think your best bet is fabbing up something with a friend who can weld, and have over with it......I didn't know anyone back when I did mine about5-6 years ago....so I bought the aftermarket thin repro for 225 bux at a car show...think it was the '97 Cypress Gardens show...not sure...maybe '98....
at any rate I drilled drain holes in it for stopping rust problems...also in my replacement but still solid front frame thwart, what that support rests on....
GENE
Old Jun 6, 2003 | 02:02 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Re: radiator support (mrvette)
The first part I sold off of my 80 was the radiator support. Not that its the same as yours, just to say they are a hot item. I could have sold four more if I had them.
Old Jun 6, 2003 | 04:13 PM
KWIL's Avatar
KWIL
Default Re: radiator support (LAvetteman)
I have seen a few used ones- but none for my year.
I wonder- is there really that much difference between the various C3 rad support designs? Maybe a different year support would work with a few mods (bolt hole locations) - anyone know?
Old Jun 6, 2003 | 08:19 PM
76Frankenstein's Avatar
76Frankenstein
I know of no cheap source...but after literally months of waiting for what turned out to be wrong part numbers or flimsy, incorrectly built repros which I had to return, I ordered a GM from http://www.vipcorvette.com/. Be sure to measure your bottom saddle bracket distance and shroud support stud spacing...from what I was told these may vary since our 76 was a transition year on this part. Also, my original had captive nuts welded to hold the upper saddle brackets - the replacement from GM does NOT have these, so I had to have a guy weld nuts there. Forget which size...oh, and Doc Rebuild sells hardware kits which contain the nut/bolts/shims etc. to replace the rusty old stuff. If you need the info, email me and I'll try to dig it up -maybe get some pics.Good Luck!
Old Jun 6, 2003 | 11:21 PM
NHvette's Avatar
NHvette
The rusted ones can sometimes be repaired.
Here are pics of the job I did on mine:
http://forums.corvetteforum.com/zerothread?id=536014
Here is another post of the support(s) before starting:
http://forums.corvetteforum.com/zerothread?id=533389
:seeya
[Modified by NHvette, 11:33 PM 6/6/2003]
To radiator support
