Leaky Intake
Old Jun 9, 2003 | 11:43 AM
SC71LT1's Avatar
SC71LT1
Default Leaky Intake
I discovered that my intake is leaking on the firewall side through the rubber rail gasket. Generally, I lay the rail gasket down and Permatex the corners before installing the intake. I would appreciate some recommendations on install method to ensure a good seal. I was told to put a light coating of High Temp Black Permatex under the rail gaskets as well as on top in the corners. thanks
Old Jun 9, 2003 | 12:04 PM
zwede's Avatar
zwede
Default Re: Leaky Intake (SC71LT1)
Don't use the end gaskets. Apply 1/4" thick bead of RTV instead. GM has been doing it like this for over a decade.
Old Jun 9, 2003 | 12:06 PM
Fevre's Avatar
Fevre
It si beyond me why they can't make a one piece intake gasket like they have done for the oil pan. Must say to leave out the rubber gaskets and just use a bead of sealant in place of the rubber gasket. I have had it not leak using the rubber gasket and have it leak just using sealant so in my book it is a toss up.
To Leaky Intake
