MSD Help!!
Old Jun 10, 2003 | 12:32 PM
Mikeb690's Avatar
Mikeb690
Default MSD Help!!
I'm ready to go to Electronic ignition....I've been doing a search on here to find out exactly what i need but can't put all the pieces together. I was looking at the 8572 distibutor and the 6A1. If I go this route what else will I need or have to change? Or what other options do I have? :confused:
Thanx for all your help!!
Old Jun 10, 2003 | 01:33 PM
redvetracr's Avatar
redvetracr
Default Re: MSD Help!! (Mikeb690)
MSD coil!! (Blaster 2)
Old Jun 10, 2003 | 02:44 PM
7vettes's Avatar
7vettes
From: If I say it's safe to surf this beach ......then it's safe to surf this beach
If you're using Solid Core spark plug wires they'll have to go, they cause too much electro-magnetic interference.
Old Jun 10, 2003 | 03:08 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Default Re: MSD Help!! (redvetracr)
I would just save money and use your existing coil. The box and the distributor are all you need unless you have a roller cam then you need a bronze distributor gear.
Old Jun 10, 2003 | 04:00 PM
theandies's Avatar
theandies
Default Re: MSD Help!! (Sigforty)
The 8572 and the 6AL is a good combination. I also have the blaster 2 coil and 8mm MSD superconductor wires. If you go with the 8572 and have a roller cam they you don't need to change the gear. It is setup for the roller cam already. The only "problem" you may run into is wiring. The 6AL box is recommended that you wire the power and ground directly to the battery and since our batteries are in the back it makes for some interesting wiring schemes. I was lucky, my engine and tranny were out when I installed mine so I ran it in the same clamps with the starter wires through the tunnel.
sigforty - I think you mean a melonized (hardened) gear, not bronze (unless a melonized gear is bronze).
I love my system....very tunable.
Old Jun 10, 2003 | 04:07 PM
Schmucker's Avatar
Schmucker
Default Re: MSD Help!! (7vettes)
Holy crap. I just figured out why the MSD box my dad had on his '64 wouldn't work. It's got to be for that reason. It worked at idle, but then it died on acceleration.
Old Jun 10, 2003 | 05:43 PM
7vettes's Avatar
7vettes
Default Re: MSD Help!! (Schmucker)
Go to this site and do a search for Solid Core.
http://www.msdignition.com/
[Modified by 7vettes, 8:08 PM 6/10/2003]
Old Jun 10, 2003 | 06:04 PM
Sigforty's Avatar
Sigforty
Default Re: MSD Help!! (theandies)
The Bronze MSD gear is hardened for use with racing and roller cams. I talked to the MSD reps on the Power Tour and they told me exactly what I needed to work with the ZZ4. They said the gear on the distributor is an iron gear and not meant for use with roller cams.
Old Jun 10, 2003 | 06:07 PM
Fevre's Avatar
Fevre
Some retro roller cames like my Crane have iron dist gears so check with the manufacturer to be certain. Seems a bronze dist gear would chew up a cam with a iron dist gear but I am not sure.
To MSD Help!!
