I need a little help with some wiring and bracket issues.
Old Jun 10, 2003 | 08:12 PM
phoenix's Avatar
phoenix
Default I need a little help with some wiring and bracket issues.
I'm finishing the exhaust and mounting all of the accessories, hoses etc...
Since I don't have good pre-engine removal photos, can anyone show me how the power steering pump rear bracket mounts? I have the front two bolts attached, but I don't see how the bracket in back mounts to the motor mount.
Also, which wires go to the different posts on the starter? I am replacing them since they are all melted, but I can't tell where they all go and the wiring diagram doesn't help.
Finally, since I have the new TPI and AC wiring harnesses, what do I do with all of the other wires? Should I unravel them all the way back to the fusebox? Can I just cut them off somewhere and tape them up? Same question with the other wires that were used with the 3 wire alternator.
Thanks a lot. :)
I still hope to get this on the road in a week, but I have a lot to do. :)
Old Jun 10, 2003 | 08:33 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: I need a little help with some wiring and bracket issues. (phoenix)
it uses one of the motor mount bolts to hold it in place,souinds like your getting close
[Modified by patsnitrovette, 8:34 PM 6/10/2003]
Old Jun 10, 2003 | 08:56 PM
dath's Avatar
dath
I would not simply cut and tape wires under any circumstance. If you want to extend or replace wires, you can cut them, but you should either use a quality crimp type connector, or solder and use heat-shrink tubing. Someone with more automotive sense may know of better options as well, but cutting and taping is just not good.
Old Jun 10, 2003 | 11:00 PM
phoenix's Avatar
phoenix
Default Re: I need a little help with some wiring and bracket issues. (dath)
I'm planning on soldering and shrink tubing any connections, but what about the original harness that I no longer need? I don't just want the unused wires sitting there, any ideas?
Thanks Pat... do you have a pic of the bracket and how it attaches? I know where it's supposed to go, but it doesn't seem to fit the way that I have it.
Thanks. :)
Old Jun 10, 2003 | 11:12 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Maybe go on to the Zip site and look at the parts listing for the PS pump and bracket. I'm pretty sure it has a picture of how everything goes together. As far as your wiring, you could carefully remove the wires you don't need at the 2 piece connector to the fuse block and it wouldn't look hacked. :smash:
Old Jun 10, 2003 | 11:29 PM
PatsLs1vette
ill go out right now and take a shot of it,ill be right back
Old Jun 10, 2003 | 11:36 PM
PatsLs1vette
Default Re: I need a little help with some wiring and bracket issues. (patsnitrovette)
Here you go.......
Old Jun 11, 2003 | 02:35 PM
phoenix's Avatar
phoenix
Thanks Pat. That helps.
My bracket looks a little different than yours. I think that is why I am having problems. Is yours just a flat piece of metal? Mine is an "L" with a curve in it.
Maybe I just need a new bracket?
Thanks. :)
Old Jun 11, 2003 | 02:59 PM
PatsLs1vette
yes its kind of an l with a curve to it that bolts also at the bottom of the block with 2 bolts from the power steering pump.
To I need a little help with some wiring and bracket issues.
