testing tach on 76?
Old Jun 11, 2003 | 03:35 AM
JohnG76's Avatar
JohnG76
Default testing tach on 76?
does anyone know what kindof voltage/current is suppose to be comming out of the brown wire from the distributor to the tach? just check to see if tach is bad or distributor connecter.
Old Jun 11, 2003 | 09:16 AM
zwede's Avatar
zwede
Default Re: testing tach on 76? (JohnG76)
12V square-wave. you need to generate a square wave signal as the tach is showing the frequency of the signal, not voltage.
