While-I-Am-At-It: change water pump?
Old Jun 11, 2003 | 02:02 PM
desi's Avatar
desi
Default While-I-Am-At-It: change water pump?
Is it a good idea to replace the wp while I am doing a cam swap. It could be the original one. But there are no problems with it.
Thanks in advance.
:cheers:
Old Jun 11, 2003 | 04:07 PM
Bobchad's Avatar
Bobchad
Default Re: While-I-Am-At-It: change water pump? (desi)
I would. They are fairly cheap and it is a pain in the rear to get back to this point.
Old Jun 11, 2003 | 04:25 PM
mvftw's Avatar
mvftw
Default Re: While-I-Am-At-It: change water pump? (Bobchad)
Replace it and keep it...
Old Jun 11, 2003 | 11:08 PM
isosceles's Avatar
isosceles
if your car runs the slightest bit warm, get a Stewart high flow pump. I'd say it is one of the best things I've done for my motor. Dropped temps 30-40 degrees.
Old Jun 11, 2003 | 11:13 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: While-I-Am-At-It: change water pump? (isosceles)
:iagree:
Old Jun 12, 2003 | 04:49 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
There are better W-pumps than stock chevy. :yesnod: And Edlebrock is one I like in aluminum - polished too. Yes, at cam change is definetly a good time. Now can you have too much cooling - possible but not probable. Can you have too much reliabilty - not possible and not probable. :D
Old Jun 12, 2003 | 08:29 AM
desi's Avatar
desi
Default Re: While-I-Am-At-It: change water pump? (cardo0)
.... Now can you have too much cooling - possible but not probable.....
Actually the car runs TOO cool...on a warm day, mixed city/highway driving, it would only hit 160. I changed to a 180 thermostat, now plan on putting 195 when the new cam goes in....
Thanks guys. I will be ordering a new (rebuilt) pump today from AC Delco.
:cheers:
To While-I-Am-At-It: change water pump?
