Big block carb options?
Old Jun 11, 2003 | 10:32 PM
73 LS-4's Avatar
73 LS-4
Default Big block carb options?
Well I'm about sick of my quadrajet again :rant: , it runs absolutely flawless except for going from high rpm in one gear and then getting out of the throttle push in the clutch switch gears and jump on the throttle again and it lays down for a bit then takes off. due this same scenario at 3500 rpm and you probably won't get this bog, due at at 5500rpm and you sure will. It acts like it's out of fuel going into the next gear. Everything else except this scenario is great, throttle response is good, gas mileage is fairly good given what I'm feeding, starts withiout the use of the accelerator pump in the morning, acceleration while in any one gear is fine all the way to the rev limiter at 5500. As I said perfect except for this problem. Anyway been considering another carb as replacement, the problem is that I have a spreadbore L-36 intake so a spacer would be needed for any holley or demon, etc. that I would use as replacement and hood clearance is at a premium under there. I'd be interested in hearing what others have used to change carbs and retain the stock hood, also suggestion on which carb to go with.
:cheers:
Pat Kunz
Old Jun 11, 2003 | 11:11 PM
joe73vette's Avatar
joe73vette
Default Re: Big block carb options? (73 LS-4)
I take it you are shifting quickly? There are ways to get fuel out faster when the air door first opens, I think by drilling out the little fuel holes in front of the air door edge. Maybe the door just isn't opening fast enough? Don't give up, send an e-mail to Lars, he has all kinds of Q-jet knowledge in his tech papers, and will e-mail them to you.
No good will come from an adapter between a square bore carb and a spread bore manifold. You'll just create different problems.
Joe
Old Jun 11, 2003 | 11:33 PM
bigvette1's Avatar
bigvette1
Hey Pat,
I have run a Holley Avenger 770cfm on my 73 LS-4 and it ran great. I used the adaptor - spacer for square bore to spread bore. Bought the one at Autozone for $15. Took a little plumbing work with the power brake line and other hoses along with the fuel line. Cut the steel fuel line and ran a rubber fuel hose into the Holley double feed assembly. The stock throttle lines will work, just need a little bending etc. You also need to pick up +12 from the throttle solenoid for the electric choke on the Holley.
I was able to use a 14" Chevy air cleaner and a reduced size filter, think it was a 2" instead o fthe 3 1/2". It cleared the stock hood ok. Thanks to the cowl induction recess.
How did it run - smooth and plenty of power. Your problem may be something other than the carb. Do you have sufficient fuel pump pressure? Do you have a kinked "S" hose? Is your float set too low for not enough fuel in the bowl?
Old Jun 12, 2003 | 01:41 PM
Robd's Avatar
Robd
Default Re: Big block carb options? (bigvette1)
I had Jones fuel systems out of California build be a QJ. It was built to the specs of my L36 and also has an electric choke. I love it
Old Jun 12, 2003 | 02:30 PM
Tominator's Avatar
Tominator
Edelbrock has the Thunder series carbs for under $400.00. Or Summit sales the Edelbrock factory reconditioned carbs, the 750 performer is under $180.00.
Old Jun 12, 2003 | 06:43 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
you need to drill out the secondary well feeds. get doug roes book and it shows it clearly how to do this. i have done this on drag race and circle track Q jets and it works.
Old Jun 12, 2003 | 10:35 PM
iniguy's Avatar
iniguy
I suggest leaving the Q-jet alone, don't drill it, don't fill it just find someone that understands how they work and you won't believe how good they really are. ...But if you choose to replace you will need a holley list # 6210 this is a double pump q-jet performance replacement carb. They have mechanical secondaries and work very well with a four speed with just about any gear ratio. May not supply enough fuel if your heads and cam move alot of air. Another option is the 850 CFM version but I can't for the life of me remember the list number. I see them often on Ebay and the last one I bought was $90. Both of these carbs are a perfect bolt on and fit under the hood, no hacking, no chopping and no mickey mouse fuel line changes. Stock air cleaner also works.
Good luck.
Old Jun 12, 2003 | 11:45 PM
73 LS-4's Avatar
73 LS-4
Hey Pat,
I was considering the 770 becouse I remembered you mentioning that you were running one. This problem has occured with two different fuel pumps, the stock unit and the 110gph edelbrock unit that is on there now, also with the stock steel fuel line and 6an braided line that I'm running now so I don't think it has anything to do with the fuel delivery to the carb. Lars setup the quadrajet that's currently on there so I'm pretty certain everything is set correctly. thanks for your reply
:cheers:
Pat Kunz
Old Jun 12, 2003 | 11:50 PM
73 LS-4's Avatar
73 LS-4
Default Re: Big block carb options? (clem zahrobsky)
Guess you ran into this problem before on other quadrajets, but it does make sense if the secondary's are simply running out of fuel, since the engine doesn't bog so much when this happens as much as it just doesn't accelerate for a second and then it goes. I'm a little hesitant on drilling holes in my matching Q jet, but maybe I can find someone that will do this for me for a fee.
Pat Kunz
Old Jun 13, 2003 | 07:37 PM
73 LS-4's Avatar
73 LS-4
anymore input :D
Pat Kunz
[Modified by 73 LS-4, 6:37 PM 6/13/2003]
Old Jun 13, 2003 | 08:53 PM
The Dude's Avatar
The Dude
anymore input :D
Pat Kunz
Big blocks and D.P. Holleys go together like PB&J, man.
To Big block carb options?
