Help w/ engine identification
Old Jun 16, 2003 | 09:48 AM
1974slcvette's Avatar
1974slcvette
Default Help w/ engine identification
Good morning everyone!! I have a question regarding my engine. I have searched high and low, and cannot seem to find any reference for the engine i.d. on the front of my block. I know it is a 350 (GM casting # 14016379), but the number on the front is: VK 202800. I think it may be a replacement or crate engine, but any feedback would be greatly appreciated. This is NOM in my 1974.
Old Jun 16, 2003 | 01:07 PM
no_radio's Avatar
no_radio
Default Re: Help w/ engine identification (1974slcvette)
crud, my engine book is at home so I can't help unless I get online tonight at the house...but I'll bump it to the top...
Jeff
Old Jun 16, 2003 | 01:28 PM
1974slcvette
Default Re: Help w/ engine identification (no_radio)
I have checked the "Cherolet by the Numbers" book, and it is not listed. The block dosen't have any suffix code...
Old Jun 16, 2003 | 01:48 PM
topless68's Avatar
topless68
14016379 is '78-'79 passenger car and light truck 350.
I do not have the proper book in front of me to decipher the VK...
[Modified by topless68, 12:49 PM 6/16/2003]
Old Jun 16, 2003 | 01:50 PM
Tom73's Avatar
Tom73
...reference for the engine i.d. on the front of my block. I know it is a 350 (GM casting # 14016379), but the number on the front is: VK 202800.
The casting #, 14016379, is for a 77-79 350. Assume that the VK 202800 is on the stamp pad (machined surface on the block in front of the passanger side head). Should be two sets of numbers stamped there. Second set would be something like V0217CLK. With that second set of #'s should be able to identify the engine.
tom...
Old Jun 16, 2003 | 02:21 PM
crm711's Avatar
crm711
Default Re: Help w/ engine identification (Tom73)
Check out http://www.nastyz28.com. See if that gives you the info you are looking for.
Old Jun 16, 2003 | 03:18 PM
1974slcvette
VK 202800 is the only number stamped on the front pad... No VIN, or any other number for that matter. I'm perplexed... From the posts that I've read the engine is fron 77' - 79', but the date stamp on the block is: J 13 2. Which means the engine was manufactured in 72', 82', 92'... Seems the more research I do, the more confusing it gets. :confused:
Old Jun 16, 2003 | 04:27 PM
Tom73's Avatar
Tom73
Could be that the VK 202800 is just a stamp that the engine rebuilder used to id the engines.
tom...
Old Jun 16, 2003 | 04:48 PM
1974slcvette
I hadn't thought of that Tom, good call. A machine shop could have wiped out the original!! :thumbs:
Old Jun 25, 2022 | 05:47 AM
shaggyman's Avatar
shaggyman
4th Gear
Hi Vel, I'm digging up your old thread because I'm looking at buying an old engine that has very similar ID and wondering if you had ever found any more info on it ( horsepower / 2 or 4 bolt mains etc).
My block casting number is the same as yours 14016379
My engine code is VK132800
The engine was being used to power a foam pump for a fire department so I'm thinking it could be some sort of crate or special order code.
Old Jun 25, 2022 | 06:35 AM
derekderek's Avatar
derekderek
he hasn't been on the forum since 2009. you can try sending a private message to him. if he has it turned on, he will get an email saying he has a PM. if he still has and checks the same email address.
Old Jun 25, 2022 | 08:09 AM
shaggyman's Avatar
shaggyman
4th Gear
Thanks Derek
To Help w/ engine identification
