Fuel Pump or Carb Problem? Help
Old Jun 16, 2003 | 10:57 PM
cmg1's Avatar
cmg1
Default Fuel Pump or Carb Problem? Help
Car has been cutting out during driving,
What are the symptoms of a bad fuel pump?
Driving down road (with gas) and all of a sudden, starts to die, sputters, etc and stops dead.. It does start again but takes a long while. Then all of a sudden, starts to go like nothing happened.
Carb is orig rodchester, rebuilt a couple of times. Fuel pump replaced about 11 years ago (15,000 miles).
All help appreciated.
Old Jun 16, 2003 | 11:14 PM
tnt76vette's Avatar
tnt76vette
Default Re: Fuel Pump or Carb Problem? Help (cmg1)
If ya havent already, change your fuel filter. Do the easy things 1st. :yesnod:
Old Jun 17, 2003 | 11:06 AM
Surfer69's Avatar
Surfer69
If electronic ignition like pertronix, could be going bad.
Old Jun 17, 2003 | 01:03 PM
Alwyn678's Avatar
Alwyn678
Default Re: Fuel Pump or Carb Problem? Help (Surfer69)
Aint that the truth........I would check the carb and the filter first for sure :cheers:
Old Jun 17, 2003 | 01:20 PM
pra4sun's Avatar
pra4sun
Default Re: Fuel Pump or Carb Problem? Help (Alwyn678)
I had the same problem a few years ago. I replaced everything (rebuilt carb, fuel filter, new coil, new fuel pump, et.) and it still would randomly cut out.
The culprit: a $3 engine kill switch that went bad.
Old Jun 17, 2003 | 01:26 PM
ukvette72's Avatar
ukvette72
Hi
when i first hade my corvette it exhibited similar symptoms, it turned out to be the condensor in the distributor. You might try this first, as someone else said try the easy (cheap) things first.
:seeya
Old Jun 17, 2003 | 01:32 PM
mvftw's Avatar
mvftw
Default Re: Fuel Pump or Carb Problem? Help (ukvette72)
Are you running HEI? If so change your module...
Old Jun 17, 2003 | 04:10 PM
R1234's Avatar
R1234
After it quits running take the breather cover off and look to see if fuel is squirting out of both nozzles as you pump the accelerator lever.
You should have two good streams of gas with each pump of the accelerator lever. If not, it could be the fuel pump.
Old Jun 17, 2003 | 07:26 PM
1Bad69's Avatar
1Bad69
when it stalls, do you smell gas like it has flooded out?
Old Jun 17, 2003 | 08:11 PM
JB's Avatar
JB
St. Jude Contributor
Default Re: Fuel Pump or Carb Problem? Help (1bad69)
If it's not fuel, could be a plugged cat. I don't know what year your car is, so I don't know if it has 'em, but the symptoms are a lot like what you describe.
JB
Old Jun 18, 2003 | 09:51 AM
Tom454's Avatar
Tom454
Default Re: Fuel Pump or Carb Problem? Help (JB)
Usually sputters when going up-hill??
Water in the tank. You can't easily see it... but it's there.... under the gas... by the pick up.
Fuel sloshes going up hill... water moves around... gets sucked up to carb... engine stalls. Heat of engine/carb evaporates water.... car starts back up.
Just a guess of course.
Plugged filler neck water drain tube, or chronically empty tank (condensation) is cause.
Took me 2 years to figure this one out... then I had to replace the rusty tank.
To Fuel Pump or Carb Problem? Help
