Rebuilt engine burning oil ??
Old Jun 18, 2003 | 06:19 AM
British Mark's Avatar
British Mark
Default Rebuilt engine burning oil ??
I have just fitted a rebuilt 350ci 1969 engne in my vette to replace the tired 307ci someone had fitted. The engine was built by a reputable shop, The problem I have is once the engine is warm it is belting out blue smoke at idle, if I rev up to 1500rpm the smoke goes but comes back at idle. The car runs great apart from this, I got a friend to follow me driving down the road and he said it only puffs smoke when I step hard on gas pedal, when I back off the gas after accelerating and on gear change. I have spoke to guy who did the engine and he admitted it should not smoke but suggested that since the block had been stood for six months for rebuild to fitting that it probably just wanted a good run, I have since done a 100 miles with no improvement so I plan to get back onto him. So has anyone got any thoughts on possible cause so I can at least look like I have some idea in case he tries to blind me with tech talk.
Any help would be great !
Mark.......
Old Jun 18, 2003 | 07:06 AM
pws69's Avatar
pws69
Default Re: Rebuilt engine burning oil ?? (British Mark)
Back to the builder - now!
Old Jun 18, 2003 | 07:17 AM
Graemeinvette's Avatar
Graemeinvette
If it wasnt for the belting out blue smoke at idle when warmed up I would have said valve stem oil seals, but lots of blue smoke at idle especially when warm suggests a bit more. If they are a reputable dealer they should fix it, if they did not install it, better check all ancilleries are working properly before you take it back and be sure and check your oil level after 100 miles+ with that much smoke it should be down at least a pint. Also take the plugs out and check them in case one is more heavily oiled up than the others, then you can point to that cylinder(s). :cheers:
Old Jun 18, 2003 | 10:17 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Was the engine bored and fitted with new pistons/rings? If so then YES take it back to the builder. OTOH, if the bore was re-used then new rings will need to be broken in, to work with the old bore. Give it 500 miles to 1,000 miles depending on the age and miles on the old block.
Old Jun 18, 2003 | 10:59 AM
British Mark
Default Re: Rebuilt engine burning oil ?? (SanDiegoPaul)
Not sure about the bores I think they were just honed but he did fit new crank, pistons and cam. If it is that the rings still have not seated souldent it somke even under acceleration ?
Thanks Mark.
Old Jun 18, 2003 | 11:01 AM
Graemeinvette
Thats what I would have thought :yesnod: :yesnod:
Old Jun 18, 2003 | 11:09 AM
zwede's Avatar
zwede
Back when I bought mine I had the same symptoms (got a good deal on the car partly because of that). The engine was a fresh rebuild, yet smoked at idle as well as when letting off the gas.
Turned out to be torn valve seals. They had used double valve springs where the inner spring was of such small diameter that it grabbed the umbrella seal and shredded it. I had to remove the heads and install PC-seals and no more smoke.
Old Jun 18, 2003 | 11:21 AM
Graemeinvette
Default Re: Rebuilt engine burning oil ?? (zwede)
:yesnod: Thats the way I was thinking Zwede, but hadn't come accross the smoky idle before. They must be really torn up for that to happen :eek:
Mark I would be interested to hear who built it for you, (offline) maybe you could drop me an email?
:cheers: :cheers:
Old Jun 18, 2003 | 12:07 PM
British Mark
Default Re: Rebuilt engine burning oil ?? (Graemeinvette)
I bought the block as a 1969 short block and the engine guy supplied the heads (1970 camle hump) which He said he has fitted new springs, would he have to have fitted new seals as well ?
Mark...
Old Jun 18, 2003 | 12:29 PM
zwede's Avatar
zwede
1 quart every 200 miles. :eek: :eek: :eek:
After the new seals the consumption dropped to about a quart every 1000 miles, and no smoke. I think it sucked oil through the intake gasket. Later I switched to Edelbrock aluminum heads and EFI and now it uses just about no oil. Never touched the short-block so the cylinder walls and pistons/rings were fine all along.
Old Jun 18, 2003 | 01:29 PM
Fevre's Avatar
Fevre
Have you given the eng a good flogging to seat the rings? You have to rev it to 5000 rpm's under load to get them to seat properly. GM recomends waiting till about 500 miles but others say to do it right away. Either way you have to get some pressure built up in the cylinders to get the rings to seat properly.
[Modified by Fevre, 1:17 PM 6/18/2003]
Old Jun 18, 2003 | 01:46 PM
Clink69's Avatar
Clink69
My symptoms after build were similar. I figured it out since the builder couldn't. :confused: Turned out the intake wasn't torqued down. After I did that it went from QT every 200 miles to QT every 2000 miles. This is a cheap easy fix 5 minutes...
Old Jun 18, 2003 | 04:01 PM
Col-UK's Avatar
Col-UK
As others have said.. could be faulty / missing / worn oil seals
Also could be worn valve guides. If you have both these things, then smoke would be worse. More noticable at idle because of stong inlet vacuum pulling oil down the valve stems. Vacuum reduced as you throttle up.
Old Jun 18, 2003 | 05:03 PM
Paul 75 L82's Avatar
Paul 75 L82
Default Re: Rebuilt engine burning oil ?? (Col-UK)
I don't see anyone talking about what oil you are using. Don't use synthetic oil to break in a motor. I suggest using Castrol Oil for break in. The synthetic won't let the rings seal. As for valve seals. I believe you should replace them every time you pull the heads. In your case you should have replaced them if the heads had been used before you installed them.
Old Jun 18, 2003 | 05:30 PM
lapdog's Avatar
lapdog
Default Re: Rebuilt engine burning oil ?? (Paul 75 L82)
I had a problem similar to this in an old continental flathead engine a friend built for me. It turned out that he had installed the rings wrong.. It ran but would not quit smoking. They were sealed power rings btw.
Good Luck
Old Jun 18, 2003 | 05:36 PM
87bob's Avatar
87bob
Veteran: Coast Guard
If you are using a synthetic like Mobil 1 it may not allow the rings to seat in. My motor rebuilder told me not to use it untill I had several thousand miles on the rebuild.
Old Jun 18, 2003 | 05:50 PM
zwede's Avatar
zwede
Default Re: Rebuilt engine burning oil ?? (87bob)
Well, GM fills LT1/4's and LS1/6's with synthetic at the factory...
To Rebuilt engine burning oil ??
Old Jun 18, 2003 | 11:53 PM
Phlash's Avatar
Phlash
Couple of other thoughts:
Check the compression on each cylinder.
1. If it is good then check seals and intake.
2. If compression is bad, check the difference between cylinders. If you see more than 3-5 lbs, then suspect broken ring or improper orientation of the ring gaps
Are you sure it is not fuel rich carburation? Smoke can look blue and be mistaken for oil.
Hope it helps :seeya
Phlash 72 BB Roadster
Old Jun 19, 2003 | 04:45 AM
British Mark
Default Re: Rebuilt engine burning oil ?? (Phlash)
Thaks for the info,
I have given it a good blast to help seat the rings, I have 14/40 oil and plan to change it this weekend to 20/50. I will take the car back to the engine builder and seewhat he thinks, I hope it is as simple as valve seals. I will let you know the outcome.
Mark.......
Old Jun 19, 2003 | 10:39 AM
87bob's Avatar
87bob
The honing process is different from the factory than most rebuilders can do.
