Torque Spec for Diff Cover Bolts?
Old Jun 23, 2003 | 10:29 PM
72 Stingray's Avatar
72 Stingray
Default Torque Spec for Diff Cover Bolts?
Hey Guys,
My service manual is AWOL and I need the torque specs for the rear cover bolts (to the housing). It's a 72 rear with a newer style HD cover.
Anyone got the #s handy?
Thanks!
72 Convertible
Frame-Off & BB/TKO Conversion in Progress
Old Jun 24, 2003 | 12:42 AM
RJR99SS's Avatar
RJR99SS
Default Re: Torque Spec for Diff Cover Bolts? (72 Stingray)
thats not really a torque critical place. It simply has to be tight enough to compress the gasket, but not so tight that it cuts the gasket.
Transmission pans, valve cover gaskets, rear diff covers; things like that should all just be as tight as you can get it with a nut driver.
Old Jun 24, 2003 | 12:45 AM
mrvette's Avatar
mrvette
3 healthy taps with a 1/2 inch impact shoud do it....
5 on lug nuts...
GENE
Old Jun 24, 2003 | 06:12 AM
guppie's Avatar
guppie
St. Jude Donor '08
According to my 74 service manual the torque on the carrier cover is 50fp :cheers:
Old Jun 24, 2003 | 07:48 AM
Gordonm's Avatar
Gordonm
Default Re: Torque Spec for Diff Cover Bolts? (guppie)
My 72 manual says 50 ft/lbs also. Never torque anything with an impact wrench. Most are capable of 150 ft/lbs or more. Many a broken bolt with an impact. Great for removing but use a torque wrench for installing.
To Torque Spec for Diff Cover Bolts?
