high speed blower
Old Jun 25, 2003 | 07:52 AM
armailman's Avatar
armailman
4th Gear
Default high speed blower
can not find the problem with the high speed on the blower of 70 vette. on my old chevelles it was the pigtail at the heater box. any info would be helpful.
Old Jun 25, 2003 | 02:50 PM
rdrman's Avatar
rdrman
Default Re: high speed blower (armailman)
It should be above the blower on th fire wall.
Old Jun 25, 2003 | 03:13 PM
Ken74Conv's Avatar
Ken74Conv
There should be a fuse holder in a single wire under the left front fender.
That fuse is probably blown.
:cheers:
Old Jun 25, 2003 | 03:20 PM
Jvette73's Avatar
Jvette73
It could also be the high speed relay. Console switch is not heavy enough to carry the current of the motor at high speed so there is a relay mounted in the engine bay. On my 73 its located on the a/c housing. The console switch activates the relay and connects power for the high speed setting. When you find the relay look for the fat wire comming in. That wire should be hot when the key is on. The console switch activates the relay which allows that power from that fatter wire to pass thru the relay to the blower motor. At least this is a basic idea of how it works and might help you diagnos.
Old Jun 25, 2003 | 03:22 PM
Jvette73's Avatar
Jvette73
armailman, BTW, im a rural letter carrier too. Out here in Md.
To high speed blower
