accelleration problems - please help!
Old Jun 25, 2003 | 10:59 PM
Scudd's Avatar
Scudd
Default accelleration problems - please help!
Upon accelleration from a full stop or in passing while driving, the car has a tendency to pull toward the left. When I pull my foot off the gas, the car pulls back toward the right. I don't think it's an alignment issue as it is only on accelleration and doesn't pull to either side when cruising. I've heard bad side yolks may cause this. Any ideas or thoughts as to the cause?
Old Jun 25, 2003 | 11:02 PM
QuickVet's Avatar
QuickVet
Default Re: accelleration problems - please help! (Scudd)
dont have a clue how to fix that. but i would start simple like tire pressure. :confused:
Old Jun 25, 2003 | 11:03 PM
LFZ's Avatar
LFZ
i had the same problem with mine...i cured with a new steering box.
Old Jun 25, 2003 | 11:04 PM
isosceles's Avatar
isosceles
from what I've heard, worn trailing arm bushings can cause that behavoir. I've heard it from a long time vette owner and from Van Steel. My car used to do that, almost change lanes on me. Not any more, Van Steel T-arms solved that.
To accelleration problems - please help!
