Engine options...
Old Jun 26, 2003 | 03:50 PM
BB wowbagger's Avatar
BB wowbagger
Default Engine options...
Since i blew my 454 ,i`m now building a new one.. :smash:
I`ve got some diffrent head options to choose.
The block is a 454 two bolt .030 bore,Cast crank,3/8 rods with ARP bolts,Mech Roller Comp cams 288R.Edelbrock RPM intake and a 850 DP and Hooker sidemounts.Main and head bolts are ARP.
I`ve got a set of 781 heads with 2.19/188 valves and a set of 702 heads with 2.19/188...
Any ideas on what heads to use? :cheers: :cheers:
Old Jun 26, 2003 | 03:59 PM
Fevre's Avatar
Fevre
Default Re: Engine options... (BB wowbagger)
Flow numbers on the stock 702 heads:
No listing for the 781.
http://www.chevyhiperformance.com/techarticles/41598/
[Modified by Fevre, 3:00 PM 6/26/2003]
Old Jun 26, 2003 | 06:24 PM
Flareside's Avatar
Flareside
Default Re: Engine options... (Fevre)
I wouldn't use those flow numbers. 354 cfm from a 253cc port at .600 lift? I wish! :lolg: Looks like a typo.
The 049 is basically the same as the 781.
[Modified by Flareside, 6:25 PM 6/26/2003]
To Engine options...
