Need suggestions for the rear end of my 383/TH350 '76. What would it take to munch on a C5 Z06 and still be very streetable? Will the 3.08 perform with the following...
383
Heads - Wedge/Fully ported, Large Valves, 1.94 intake, 1.6 Exh
6way comp valve job
11:1
Holley 750 DP Mech.
Weiand Stealth Intake, match port
Running 2:1 Cam2 110
Hooker headers, 4" sidepipes
Crane Roller cam, Scorpion 1.5 roller lifters
0.050 lift, Int lift 0.561, Exh lift 0.561, lobe center 116.0, Overlap 22.0, Int Dur. 250.0, Exh Dur. 258.0
Minimum RPM 3700, Max. RPM 7200, Valve float 7800
Specs say 465 HP
TH350
HD rebuild...Kevlar...shift kit...had to replace the 3500 stall...too much for the street. Going with 2500...resetting shift points.
NOS 250 Cheater system
Zip Performance suspension...360 lb. rear spring, etc.
Will be running on 255/45/17 Firehawks most of the time...
Im my opinion, 3.55 mmis a nice all around ratio that allows both improved performance off the line & still allows some freeway driving. I've driven my car on the freeway with my 3.90's and it can get to be a bit rough without an O/D gear ;) .
The 3.55:1 is the intermediate between a long and a short ratio.
I changed from 4.11 to 3.55 on my 396 Z11 Camaro. One of the first things I noticed was that the fuel consumption decreased. Then, less shifting and higher speeds on less rpm. I'm really happy with this combination, and that's the one I just installed on my 68 vette now. Again as everybody says for cruising keep the long ratio (under 3.55's) :thumbs:
For decent rear gears to be streetable, especially if you like to cruise on the highway, you might wanna look into an O/D trans/gear swap. The 3.90/2004r setup I got is pretty sweet. 2250rpm@65mph in 4th. Tons of TQ from the hole. Only challange is to get the tires to stick.
:smash: :cheers:
I'm so sorry I didn't swap out to a 200r or 700r o/d tranny. The first gear ratio on these units combined with a higher than 3:08 rear would give you the best of all worlds. Traction would be an issue. Next time..
If it's not TOO late, get a set of TCI extra-low gear-sets for a THM350. I run 'em in my THM400 in my Z28. 1st is 2.75 (stock is 2.48), 2nd is 1.57 (stock is 1.48). It'll give you 11% more gear in first; my 4.11s launch like 4.56s; the 4.56s launch like 5.13s, yet High (3rd) remains 1-to-1. 3.08s would 'feel' like 3.40s; 3.36s would be 3.73s; 3.55s would be 3.90s; 3.70s would be 4.10; 3.90s would be 4.30s. Don't worry about the wider RPM drop-off; I'd think your 'long arm', and the N2O, would make PLENTY of torque to 'pull' the drop-off. I'm guessing 3.36s with 2.75:1 1st gear ratio is :thumbs: :thumbs: :thumbs:
