LINE LOCKS ARE COOL!!!
Jun 27, 2003 | 12:44 AM
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Check out the 1/4 " hole I dug in the pavement
[Modified by 69 N.O.X. RATT, 6:02 AM 6/27/2003]
Jun 27, 2003 | 12:48 AM
Re: LINE LOCKS ARE COOL!!! (69 N.O.X. RATT)
Darn it I can get the pic on my sig but not the forum. Any suggestions?
Jun 27, 2003 | 12:56 AM
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
http://us.f1.yahoofs.com/users/65d9d...ip8..AIuzwgpvx
bad link of dead file name
[Modified by BSeery, 10:57 PM 6/26/2003]
Jun 27, 2003 | 06:55 AM
Re: LINE LOCKS ARE COOL!!! (BSeery)
cant see the picture. but yes, line locks R cool :D
Jun 27, 2003 | 08:04 AM
Cruise-In III Veteran
St. Jude Donor '05
Re: LINE LOCKS ARE COOL!!! (QuickVet)
Mine's still sitting in the box :cry . I can't wait to try it out :reddevil
Jun 27, 2003 | 08:20 AM
I see the picture in my profile. I am still trying to figure out how to post it. Can anyone else see it in my profile.
[Modified by 69 N.O.X. RATT, 1:21 PM 6/27/2003]
Jun 27, 2003 | 08:22 AM
No picture yet. Yes Line Locks are great.
Jun 27, 2003 | 09:25 AM
Re: LINE LOCKS ARE COOL!!! (Gordonm)
:cheers: :cheers: I have been meaning to get one installed......Though I burned my tires off this weekend
Jun 27, 2003 | 10:07 AM
E-mail me the picture and I'll post it.
Jun 27, 2003 | 10:36 AM
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Linelocks are awsome!!! :D :D
Just click below to see a nice video :D :D :D
Click here
[Modified by GrandSportC3, 10:36 AM 6/27/2003]
Jun 27, 2003 | 10:43 AM
How, exactly, does a line lock work? DOes it just do the same thing as a "brake stand" doe sin an automatic?
Jun 27, 2003 | 12:15 PM
Re: LINE LOCKS ARE COOL!!! (Mystery Machine)
A line lock (or roll control as they're sometime called) consists of an electrical solenoid that's plumbed into the brake system downstream from the proportioning valve or distribution block or pressure differential switch.
Once it's installed you hit and hold the brake pedal, press and hold a button in the cockpit and then release the pedal. At that point the brakes on the side of the brake system with the line lock installed are locked, but the others aren't.
They are commonly installed on the front brakes of a car for drag racing. Lock the front wheels and then do your burnout with the rears. This way you don't wear our your rear brake pads doing what you call a brake stand in the burnout box--you just let go of the button and the front brakes release and off you go.
You could install TWO line locks in your drag car to lock all four brakes to hold you at the starting line while you bring the RPMs up. Then, of course you would launch the car by simultaneously releasing the line lock button and stabbing the throttle. (Sort of a poor man's trans brake.)
You can also use a line lock on a tow vehicle or RV to hold you on hills, etc.
Pretty useful little gadgets, really.
[EDIT: For typos.]
[Modified by The Dude, 9:18 AM 6/27/2003]
Jun 27, 2003 | 01:11 PM
Re: LINE LOCKS ARE COOL!!! (GrandSportC3)
that's a cool vid Oliver, I like the way your sidepipes blow the tire smoke outward :cool:
Jun 27, 2003 | 01:18 PM
Re: LINE LOCKS ARE COOL!!! (isosceles)
Are you coming to the Corvette Challenge tomorrow???
