Dynamic Vs Static comp..
Old Jun 27, 2003 | 01:27 PM
BB wowbagger's Avatar
BB wowbagger
Default Dynamic Vs Static comp..
Since i`ll be running a fairly high comp on my engine (11:1) i was told that thats the "Static comp" and with a healty cam you`ll bleed off some comp(Dynamic comp?).How do i figure out what the "real" comp is? :cheers:
Old Jun 27, 2003 | 01:36 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Default Re: Dynamic Vs Static comp.. (BB wowbagger)
I believe you would disconect your ignition, install a compression test gauge and crank it.
Old Jun 27, 2003 | 01:45 PM
Fevre's Avatar
Fevre
Here is a great link thanks to gkull:
http://www.smokemup.com/
Old Jun 27, 2003 | 01:52 PM
gkull's Avatar
gkull
You have mail. I'm sending you the program. You need to know the seat to seat duration numbers off of your cam card.
Old Jun 27, 2003 | 01:53 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Dynamic Vs Static comp.. (Fevre)
DCR is dependant on cam events (effective swept volume from TDC to where intake valve closes) The DCR is a fixed number, the cylinder pressure is dependant on rpm, intake & exhaust efficiency, temperature, athmospheric pressure.. yadda yadda.... The thing to watch with high static compression is that you don't get a cam that is so short it will give high cranking pressure at low rpm, you'll need a crank retard box for it then. To bleed off at low rpm you need a longer cam, that has more pumping loss.
[Modified by Twin_Turbo, 6:00 PM 7/2/2003]
Old Jun 27, 2003 | 01:59 PM
BB wowbagger
Default Re: Dynamic Vs Static comp.. (Twin_Turbo)
The cam i will be running is a CompCams 288 roller cam..
:cheers:
Old Jun 27, 2003 | 02:16 PM
gkull's Avatar
gkull
I don't like compCams or their web site. I find it difficult to get the cam card on your 288 roller cam
I see that they now claim one day custom ground cams. I would like them to tell me why mine took 42 days and I got charged for 3 cams. They claim to sell things that they don't really have.
[Modified by gkull, 3:43 PM 6/27/2003]
Old Jun 27, 2003 | 02:21 PM
BB wowbagger
Default Re: Dynamic Vs Static comp.. (gkull)
Yes ..their site suck..But the Summit Art nr is:CCA-11-692-8
Thanks for the prog..Sitting ang playing with it now :cheers: :cheers:
Old Jun 27, 2003 | 02:24 PM
Fevre's Avatar
Fevre
There is a mech roller cam with a grind of 288AR-8 on this page. :confused:
http://www.compcams.com/catalog/108_109.html
Old Jun 27, 2003 | 02:32 PM
BB wowbagger
Heres some tech info from Summits site:
Specifications:
* Advertised duration: 288 intake/288 exhaust
* Duration at .050 in cam lift: 246 intake/246 exhaust
* Gross valve lift: .623 in. intake/.623 in. exhaust
* Lobe separation: 110 degrees
* RPM range: 2,200 to 6,500
* Great all-around power
* 3,000 plus stall with lower gear
* Use headers and 9.5:1 or higher compression
* Rough idle
:cheers:
Old Jun 28, 2003 | 02:17 PM
BB wowbagger
I have played around with the calculator and came up with 9.7:1 comp..That sdoesnt sound right,does it? :cheers:
Old Jul 2, 2003 | 07:08 PM
Twin_Turbo's Avatar
Twin_Turbo
is that for dynamic compression? That indeed doesn't sound right, it should be somewhere between 75, and 8,5 for a street engine and about as hgh as 9 for a race engine. For it to be around 9 w/ a generic 290 cam you'd need a static compression of about 12:1
To Dynamic Vs Static comp..
