Sorry if this is as stupid as it sounds as I type it :bb
Should the power steering fluid have a dipstick? My steering is making a funny noise. I remove the cap to check the level and it appears the cap it clean, but without a dipstick. CRAP....Now how difficult is it to replace the power steering pump and what is THIS going to cost me :cuss
Just when things are going great another unsuspecting project rears up.
I just replaced mine about two weeks ago. Replacement isn't really that difficult, compared to a lot of stuff on these girls. Plan to get under and on top to remove. I also removed my alternator belt (small block) to get to everything easier. You will need a puller to remove the pully from the pump.
I beleive that I paid about $55.00 for a rebuilt pump.
It has not been established that you need a pump yet. You need to check fluid level which should be covering everything inside the pump & belt tension.
While you should have a dipstick it is easy to have correct level w/o one.
Ganey's correct, I would check the level first. Should have suggested that in the first place.
If you have a salvage yard close, you can likely get a dipstick there. The pump is not a "special" Vette part. My pully was crooked and I got one off of a small block chevy in the local salvage. Ganey may have more info on that.
I bought my rebuilt pump at the local parts s place.
Just a thought...maybe the noise in your power steering unit is being caused by that dipstick you've lost! :cheers:
That is one of the thing that scares me! What would my issues be if that was the case? Are they metalic? Before I add fluid, I am going to try and fish around with a pair of needle nose to see if I can extract anything and maybe even a magnetic screwdriver. I much appreciate the answers here!
